Nov 24, 2006 - 2:41 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
ok i was wondering if someone could snap a pic of the bolt you tighten to tension the belt.
for some reason my belt tensioner is not running straight,, i think i am missing a small peice that goes ;inbetween the bolt and the metal bracket.. but not sure thanks! |
Nov 24, 2006 - 3:17 PM
Nov 24, 2006 - 5:31 PM
thanks itchy, but i need a shot of the tensioner for the normal acc belt that runs the alt and stuff.. ill check the link out though and see what im missing.
Nov 24, 2006 - 6:49 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Is the nut that holds the pulley on tightened up? The bearing in the pulley may be bad too.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Nov 25, 2006 - 10:22 AM
QUOTE(Dr_Tweak @ Nov 24, 2006 - 6:49 PM) [snapback]505077[/snapback] Is the nut that holds the pulley on tightened up? The bearing in the pulley may be bad too. -Doc yes i can make the nut tight, but the bolt still slides out of the bracket, causing the tensioner to run cocked.. could be the bearing?.. |
Nov 25, 2006 - 10:30 AM
my problem is i think im missing a peice between the bolt and the bracket.. maybe a rubber thing or something that helps hold the bolt snug in there.. its just pops out the side when i tighten it..
thats why i need a pic and i cant find a pic of the belt in any of my manuals or online.. |
Nov 25, 2006 - 10:50 AM
ok well once again im just a space shot.. all i needed to do was tighten the bolt on the face of the wheel tensioner.. since that wasnt tight against the bracket the belt tension was causing it to move the tensioner...
she is good to go thanks itchy and doc |
| Lo-Fi Version | Time is now: August 31st, 2026 - 3:41 AM |
