Nov 27, 2006 - 3:18 AM
Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
Not many people seem to be too into audio here. Just going to put up my current work in progress. This is a SQ setup. 3 way active front + sub. Headunit connected optically to h701 processor. All inputs welcome
Gear: Alpine 7998r fantomface headunit Alpine F545 amps (2 of them) Alpine CHA-S624 changer Alpine H701 processor + Rux controller Drivers: Seas L18-RNXP 7" midbass Hybrid Audio Legatia 3" mids tweeters unconfirmed(DLS UP1C or seas neo) Phase Linear Aliante 12" sub TODO list: - Cut kickpanel for install of 3" mids.(better pathlength difference and more footroom(no change from stock) - Fiberglass kicks etc. - Boot install - Reinstall midbass drivers - A pillar tweets Aliante and legatias ![]() Headunit installed in stealth manner: ![]() ![]() This video I found, shows how it works: http://www.youtube.com/watch?v=sDau1aWIvoo...ted&search= Cable routing : Convenient grommet next to battery in engine bay ![]() Inside wheelwell: ![]() Managed to fit the power cable through grommet. ![]() Ran 3 sets of speaker wires. Midbass,mids,tweets. Making sure I have enough slack in the cables to not require a rerun. ![]() ![]() Done: ![]() Will cut my kickpanels. The bit of metal to the right of the speaker wires hanging down. 1mm -ish thick. will allow me to sink the 3inch midrange speaker deeper into kickpanels and also allow more footroom and minimise pathlength difference. ![]() Trunk - About to embark on install - ![]() ![]() ![]() still deciding if I should make my life hard and have side mounted amps or just go with false floor amp setup. This post has been edited by soven: Nov 27, 2006 - 3:18 AM |
Nov 27, 2006 - 9:51 AM
Enthusiast ![]() ![]() ![]() Joined Mar 29, '06 From Hull, UK Currently Offline Reputation: 0 (0%) |
Should be good when its finished mate.
Go for the extra work side amps, you'll only end up regreting not doing it in the end. I keep meaning to get around to doing something with mine, had a couple of subs sitting in my house for 3 years now, just not had time. |
Nov 27, 2006 - 10:11 AM
Keep us updated! great job so far!
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Nov 27, 2006 - 12:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Alinate will do a great job - these subs are amazing
-------------------- Ex celica owner - just a guy from other side of the pond...
Nov 27, 2006 - 3:45 PM
Thanks for the comments. JL subs are good too and I actually played around with a jl12w6v1 but the aliante is too pretty to sell. I have a feeling that I will regret it if I do not at least attempt to do the side mounted amps.... will have a crack at it when I am free.
It will be tricky and will involve fiberglassing + mdf. The left side should house the amp and the changer right behind it accessible through a cover at the top. and the right side will house the h701 processor behind the amp. I have already played with fiberglass and made a tyre well enclosure but I guess this would be much trickier. |
Nov 27, 2006 - 8:04 PM
Finally cut one of my kicks today .
Dremel steel/fiberglass cutting disc: <---will be nightime by the time i finish ![]() Angle Grinder ;D! . Sparks was a bit of a concern but otherwise I have a feeling I might get addicted to this tool....., first time with an angle grinder. ![]() Metal bent back ![]() Sharp edges removed with dremel bit and a bit of paint was sprayed on llater to prevent any chance of rust.
This post has been edited by soven: Nov 27, 2006 - 8:04 PM |
Nov 28, 2006 - 4:55 AM
here you go mate, not exactly what you want it for but the principles will be the same for a changer enclosure.
http://www.cfsnet.co.uk/projects-speaker.html |
Dec 13, 2006 - 4:04 AM
Little update. went back to original plan.
Tyrewell fiberglass enclosure done. no pics. Router to cut a straight edge since I do not have access to circ saw or table saw.Came out great, just took longer. ![]() 45degree cut. ![]() False floor initial cutout + sub baffle .will be carpeted. ![]() Reason for the big baffle is because the tyrewell is not centered. Also allows me to remove my sub instead of having to remove the whole false floor before having access to sub. Still have to cut the hole for the subwoofer and attach the baffle to the enclosure. would be tomorrow's job. |
Dec 13, 2006 - 9:44 PM
![]() Enthusiast ![]() ![]() Joined Jan 21, '05 From NY Currently Offline Reputation: 0 (0%) |
Awsome, and please replace that Alipine with something more powerful
-------------------- <<AKA THA RUSSIAN>>
Dec 15, 2006 - 2:51 AM
the alpines are 170rms x 4 (birthcert) or 170x2 + 500x1 (4ohms) . not too popular here regarding mb quarts. Hey.... the tyre well is bad enough already and the fumes is quite bad. i recommend that people get a respirator too. fiberglass dust do not break up in your body too well.
This post has been edited by soven: Dec 15, 2006 - 2:52 AM |
Dec 28, 2006 - 8:01 AM
Dec 28, 2006 - 10:18 AM
Dec 28, 2006 - 11:30 PM
Dec 30, 2006 - 1:16 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
QUOTE(soven @ Dec 28, 2006 - 8:01 AM) [snapback]513621[/snapback] Badass. sure as hell beats the way I mounted my tweeters! keep up the good work! -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Dec 30, 2006 - 7:22 AM
![]() Enthusiast ![]() Joined Nov 16, '04 From Switzerland Currently Offline Reputation: 0 (0%) |
QUOTE(soven @ Nov 27, 2006 - 3:18 AM) [snapback]505501[/snapback] Phase Linear Aliante 12" sub nice decision, i got the same ![]() -------------------- |
Jan 4, 2007 - 4:31 AM
Enthusiast Joined Jan 4, '07 From New Zealand Currently Offline Reputation: 0 (0%) |
How is the project going , Im about to do my hatch as well... your info has been a great help
Jan 4, 2007 - 4:47 AM
Hey steel. Project is going fine. just playing around with the midrange location and also did a bit of my false floor today. The glue used to trim the a-pillars isn't holding up under the sun so I will have to re-do that somewhere down the line.
Jan 4, 2007 - 7:03 AM
Did you use a hot-glue gun mate? I used that with my rear lights and the sun caused them to come apart. I am going to retry it with some of the stuff that you use to fix bodykits on as that is also very sticky and the sun shouldn't remelt it.
Just a thought, ignore me if thats not the problem. Keep up the good work. Dan |
Jan 4, 2007 - 8:05 PM
nah not hot glue heh. I used Ados F2(contact cement) in a pot. Will have to find some other glue.
Jan 5, 2007 - 2:22 AM
contact cement shouldn't be affected by the heat of the sun I wouldn't have thought.
Try some Epoxy with the 2 tubes that you have to mix together, or like I said the bodykit adhesive. |
| Lo-Fi Version | Time is now: August 27th, 2026 - 10:51 PM |
