> 7AFE oil burner
post Nov 29, 2006 - 8:22 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
I've got a '94 S/T that loves to consume oil (1.5qt per tank). 147K on the speedo. It smokes upon start up and slightly when driving, I suspect valve stem seals. PCV valve is good. Ran a compression check and each cylinder was over 210psi. Plugs look good with a slight tan deposit on them. Anybody had a similar problem and found a fix? Not sure if should rering it or just do the stem seals. Don't have a leakdown tester to see what that shows. What ya think?
Replies (1 - 5)
post Dec 7, 2006 - 11:54 PM
rayneezy23
Joined Jun 25, '06
From Bremerton, Washington
my car does that too piston rings might have to be replaced i think i may be wrong
post Dec 8, 2006 - 12:18 AM
sounds like real bad valve stem seals. high rpm driving will make it worse.
try adding some ATF (no more than 1/2 qt ) to your oil to soften the valve seals some.
post Dec 11, 2006 - 12:43 AM
gnetik
Joined Aug 14, '04
do you have white or bluish black smoke when you start the car? if you do, then it is most likely the piston rings.
post Dec 11, 2006 - 1:33 AM
rayneezy23
Joined Jun 25, '06
what do you in that case is that the only way replacing the piston rings? If so thats a big job
post Dec 15, 2006 - 4:41 PM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
Going after the stem seals first.
Lo-Fi Version Time is now: September 15th, 2026 - 2:37 PM
