Dec 20, 2006 - 10:18 PM
Enthusiast ![]() ![]() Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) |
I just recieved my Koyo radiator and decided to install it. As I was installing it I noticed a couple of things that didn't really fit right. First, I had to install my two fans after the radiator was mounted in the car because it didn't fit when I tried to fit the radiator with the fans already on. The next thing I noticed was that the cruise control unit which is right next to the radiator is in the way of the fan on the driver side. So I had to cut into the fan. The second place that was in the way of mounting the drivers side fan was the front engine mount, so I cut a place for that also. Then the last thing that I noticed was that the A/C line was in the way of the passenger side fan, so I had to force it out of the way. Did anyone else notice these situations when installing their Koyo? Thanks
Dec 20, 2006 - 10:24 PM
you have an auto or manual?
Dec 20, 2006 - 10:31 PM
QUOTE(LewFX @ Dec 21, 2006 - 3:24 AM) [snapback]512050[/snapback] you have an auto or manual? Manual |
Dec 22, 2006 - 10:56 PM
No one had any problems with their installation?
Dec 23, 2006 - 2:25 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 27, '03 From Nor Cal Currently Offline Reputation: 0 (0%) |
You sure it's a GT radiator and not an ST? They're a bit different...
-------------------- "It's ok to be naked girl... I'm an artist!"
Dec 23, 2006 - 4:38 AM
Enthusiast ![]() ![]() ![]() Joined Apr 17, '06 From under your bed. Currently Offline Reputation: 4 (100%) |
No, if you ordered the right part, it should fit fine. Otherwise, they might have sent you a radiator for a different car. I'm pretty sure it's not for the ST becuz they DO NOT make Koyo Radiators for the ST models. Only GT models. Are you sure you didn't order from eBay? I garentee you they sent you a radiator for a different car. Find a part number on the radiator. Should be Part#R1958.
This post has been edited by ExSane: Dec 23, 2006 - 4:40 AM -------------------- ![]() |
Dec 23, 2006 - 7:34 AM
Enthusiast ![]() ![]() ![]() Joined Sep 17, '05 From Newcastle / UK Currently Offline Reputation: 4 (100%) |
Ive got a KOYO on my ST205, its a very tight fit past the turbo with a 3" downpipe if keeping the stock fan setup and apart from that, like you say, just moving the AC pipe thats on a rubber mounted bush saw everything fit ok. No cruise control to contend with so no worries there and mine is an R1958.
-------------------- 1994 JDM GT4 WRC
Dec 23, 2006 - 7:56 AM
![]() Enthusiast ![]() Joined Jul 17, '06 From Portland, OR Currently Offline Reputation: 4 (100%) |
Had same problems with my installation.......
Dec 24, 2006 - 10:52 PM
QUOTE(ExSane @ Dec 23, 2006 - 9:38 AM) [snapback]512630[/snapback] No, if you ordered the right part, it should fit fine. Otherwise, they might have sent you a radiator for a different car. I'm pretty sure it's not for the ST becuz they DO NOT make Koyo Radiators for the ST models. Only GT models. Are you sure you didn't order from eBay? I garentee you they sent you a radiator for a different car. Find a part number on the radiator. Should be Part#R1958. I did buy it from eBay, but the number on the box is R1958. If I have time I'll post some pictures. |
| Lo-Fi Version | Time is now: July 9th, 2026 - 1:13 AM |
