Dec 30, 2006 - 10:14 AM
Enthusiast ![]() ![]() Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
I have the 3SGTE MR2 motor can anybody tell me how much the injectors flow on theis model?
Dec 30, 2006 - 10:25 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Which gen 3S-GTE?
2nd gen is 3rd gen is 540cc. http://www.alltrac.net/comparison.htm This post has been edited by Kadett: Dec 30, 2006 - 10:28 AM -------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Kadett @ Dec 30, 2006 - 10:25 AM) [snapback]514034[/snapback] Which gen 3S-GTE? 2nd gen is 430cc I believe 3rd gen is 540cc. To tell you the truth I am not 100 % sure its a 92 motor, but it has oil nozzles so i think it is a 3rd gen but not 100%. Are you sure of those sizes, how can i tell if it is a 2.3rd gen? -------------------- |
Dec 30, 2006 - 10:48 AM
If you look at the side of the turbo. If it says TOYOTA like in the next picture, you will have a CT20B turbo which mains you have a 3rd gen. If it says CT-26 on the side its a 2nd gen.
Picture: ![]() BTW 2nd gen is from 90-94 Everything beyond 94 is 3rd gen. This post has been edited by Kadett: Dec 30, 2006 - 10:49 AM -------------------- JDM Powerplant installed, BPU coming very soon!
Dec 30, 2006 - 10:51 AM
QUOTE(Kadett @ Dec 30, 2006 - 10:48 AM) [snapback]514037[/snapback] If you look at the side of the turbo. If it says TOYOTA like in the next picture, you will have a CT20B turbo which mains you have a 3rd gen. If it says CT-26 on the side its a 2nd gen. Picture: ![]() BTW 2nd gen is from 90-94 Everything beyond 94 is 3rd gen. no the Turbo is diffinatly a ct26, but I wanna know how you can tell if you just have the core? re- are you sure about the injector sizes it quite important, aand do you kno whaw much power they can withstand? -------------------- |
Dec 30, 2006 - 10:54 AM
a 92 is a 2nd gen 3sgte. you have a ct26 turbo with 440cc injectors. they are good for around 275hp at the wheels.
Dec 30, 2006 - 11:54 AM
ok thanks guys you have be great help
Jan 2, 2007 - 1:28 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
QUOTE(Kadett @ Dec 30, 2006 - 10:48 AM) [snapback]514037[/snapback] If you look at the side of the turbo. If it says TOYOTA like in the next picture, you will have a CT20B turbo which mains you have a 3rd gen. If it says CT-26 on the side its a 2nd gen. Picture: ![]() BTW 2nd gen is from 90-94 Everything beyond 94 is 3rd gen. Off topic but that is not true. There are CT26 turbos with only "Toyota" word casted on the compressor housing. The only way to tell whether or not the turbo is CT20B is to count the hole/stud on the exhaust outlet flange and check the casted number on the exhaust inlet flange. QUOTE(Kadett @ Dec 30, 2006 - 10:48 AM) [snapback]514037[/snapback] BTW 2nd gen is from 90-94 Everything beyond 94 is 3rd gen. Not applicable to USDM 3sgte from 94-94 MR2 Turbo. They are 2nd generation. -------------------- _Gary
Jan 2, 2007 - 1:51 AM
QUOTE(Gary @ Jan 2, 2007 - 1:28 AM) [snapback]514525[/snapback] QUOTE(Kadett @ Dec 30, 2006 - 10:48 AM) [snapback]514037[/snapback] If you look at the side of the turbo. If it says TOYOTA like in the next picture, you will have a CT20B turbo which mains you have a 3rd gen. If it says CT-26 on the side its a 2nd gen. Picture: ![]() BTW 2nd gen is from 90-94 Everything beyond 94 is 3rd gen. Off topic but that is not true. There are CT26 turbos with only "Toyota" word casted on the compressor housing. The only way to tell whether or not the turbo is CT20B is to count the hole/stud on the exhaust outlet flange and check the casted number on the exhaust inlet flange. QUOTE(Kadett @ Dec 30, 2006 - 10:48 AM) [snapback]514037[/snapback] BTW 2nd gen is from 90-94 Everything beyond 94 is 3rd gen. Not applicable to USDM 3sgte from 94-94 MR2 Turbo. They are 2nd generation. What If you dont know the year of your motor? -------------------- |
Jan 2, 2007 - 2:22 AM
The easiest way to tell is to check where the oil filter is.
On the 2nd gen engine, oil filter is on the side of the block, exhaust side. On the 3rd gen engine, oil filter is at the bottom. The intake manifolds are also different. Gen 3 has no TVIS. The timing belt cover of 2nd generation is gray, the 3rd generation cover is black. The exhaust manifold bolt patterns are also different. ![]() The injectors are also different. 2nd gen injector is 440 cc/min and has black top. 3rd gen injector is 540/min and has dark pink top and has "4" holes -------------------- _Gary
| Lo-Fi Version | Time is now: May 7th, 2026 - 1:39 PM |
