Jan 8, 2007 - 1:00 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 13, '06 From UnderTheGround403 Currently Offline Reputation: 2 (100%) |
I cant get this bolt off. I used visegrips and they just grind more metal off.
Jan 8, 2007 - 1:17 PM
cut the head off the bolt and tap it through, then cut some off the other side and tap it through back from where it came and then all the way out.
what are you trying to do exactly? remove the alternator or just change the belt? -------------------- |
Jan 8, 2007 - 1:26 PM
you need to buy yourself a set of boltouts. they are a must when working on cars. you can buy them at sears or even pepboys. here is what they look like.
http://cgi.ebay.com/CRAFTSMAN-13-PIECE-BOL...1QQcmdZViewItem -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 8, 2007 - 1:47 PM
Enthusiast ![]() ![]() ![]() Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
You have a couple of options.
You can hammer a slightly smaller impact socket on to the bolt the tighter the better and get out the breaker bar. Grind a slit in the top of the bolt and try using a flat head (probably wont work in this case?) Drill it out You could tourch it, but that ones up to you And dont forget the PB blaster One of these will get that bolt off This post has been edited by Nemises: Jan 8, 2007 - 1:48 PM |
Jan 9, 2007 - 12:49 AM
torch it a little and then use a bolt out made by craftsman (accept no imitations)
Jan 9, 2007 - 8:04 PM
Enthusiast ![]() Joined Oct 3, '02 From HOUSTON Currently Offline Reputation: 0 (0%) |
breaker bars ftw great investments
Jan 10, 2007 - 2:07 AM
Alright, im looking into getting a set of bolt-outs. Which one would be the "best" universal one? The 13 peice one in the red case or the 10 piece "low profile" one?
Jan 10, 2007 - 2:54 AM
were you using a 6 point socket?
| Lo-Fi Version | Time is now: May 25th, 2026 - 2:45 PM |
