> stock ST205 wheels, Anyone know the specs
post Jan 11, 2007 - 1:31 AM
scothaniel
Joined May 1, '03
From Michigan
Does anyone know the specs of the GT4 rims? I know they are 16" with 5x100 bolt pattern, but I dont know the offset. Trying to find a 16" that will fit over the 205 brakes so I can use the (new) winter tires I have.
I can definitely say the 7th gen rims dont fit - diameter is fine but the offset isn't enough.
Thanks.
Scott
West Michigan
Replies (1 - 5)
post Jan 11, 2007 - 3:21 AM
Gary
Joined Aug 28, '04
From FLA USA
Scott,
According to Steve (Betsy), it is 45mm.
But from what I have read, not all 45mm offset wheels will clear the caliper.
It also depends on the wheel/spoke design. (back space)
_Gary
post Jan 11, 2007 - 6:05 AM
drhossa
Joined Sep 14, '04
From Germany
offset 45, right!
post Jan 11, 2007 - 11:39 AM
block
Joined Jul 27, '06
From Soda
yeah there was a set way back on ebay...16x7 & 45 offset
post Jan 11, 2007 - 12:39 PM
Insanity-74
Joined Jan 9, '05
From Under the car
45 Offset is the correct one, but you can run other offsets...dont be tempted by subaru wheels as you`ll need a spacer....but the offset on mine is only 38 and they fit fine and clear the calipers with more room to spare than my old multi spokes with a 45 offset.
post Jan 11, 2007 - 4:47 PM
scothaniel
Joined May 1, '03
From Michigan
Great, thanks for the info guys.
Scott
West Michigan
Lo-Fi Version Time is now: September 15th, 2026 - 11:51 AM
