Jan 12, 2007 - 11:47 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
alright, I've seen alot of people say that a 5sfte set-up could be done for like $1500-1600. but everytime I sit and try to calculate a cost, I end up over $2500... could someone possibly tell me how much it typically costs for a 5sfte turbo kit? here's what I figure:
3sgte stuff (turbo, manifold, downpipe, oil pan, map sensor, oil lines) $300-400 injectors $300-400 fuel pump $100 FMIC (including all pipes, couplers, clamps) $300-500 gauges $150-200 SAFC+BTM/emanage ultimate $600 BOV $150-200 exhaust $200-300 for a total cost of $2100-2700. abd that's before any dyno tuning! is there no cheaper way to do a 5sfte? -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 13, 2007 - 12:23 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
are you going with a majority of new parts? I got my S-AFC2 for $160, but it was used, so if i got that along with a used MSD BTM, i'm not looking anywhere near $600 for that pair.
there's someone I know that's selling an almost complete used turbo kit for the 5S for about $900. -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Jan 13, 2007 - 12:30 AM
QUOTE(NgoFcukinWay @ Jan 12, 2007 - 9:23 PM) [snapback]517519[/snapback] are you going with a majority of new parts? I got my S-AFC2 for $160, but it was used, so if i got that along with a used MSD BTM, i'm not looking anywhere near $600 for that pair. there's someone I know that's selling an almost complete used turbo kit for the 5S for about $900. true, I suppose certain things could be bought used. and where can I get this almost complete 5s turbo kit? -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 13, 2007 - 12:49 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Hmm i didn't know you needed to purchase a map sensor to turbo a 5sfe. What do you get it from?
Jan 13, 2007 - 12:58 AM
QUOTE(MaskedMan @ Jan 12, 2007 - 9:49 PM) [snapback]517524[/snapback] Hmm i didn't know you needed to purchase a map sensor to turbo a 5sfe. What do you get it from? the stock alltrac or mr2 turbo 2bar map sensor. apparently, using the stock sensor messes with the ecu because the stock sensor doesn't know how to respond to the boost. or something along those lines. you might want to ask someone who knows more than I do... -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 13, 2007 - 1:26 AM
but the alltrac uses AFM. i thought the factory MAP sensor from a 5sfe was fine. could someone please let me know?
Jan 13, 2007 - 1:50 AM
QUOTE(presure2) then, i started looking for parts: 3s exhaust manifold, ct-26 turbo, oil hard lines, elbow and primary cat (also known as a downpipe), if your not planning on getting a aftermarket downpipe. also the oil pan and 2bar map sensor. QUOTE(puretone) hi, i got a 5th gen 5SFE that i turbo'd, i know i know 5gen etc whatever, same engine and i too did ALOT of research..... welded up my own manifold because i was just not impressed with the burien/OEM turbo manifold. i use a Schwitzer t3-ish turbo, found on saabs for the most part.... Supra MK4 NA injectors, non-California spec....i dont live in the USA anyways, these suckers spray about 550cc (!) Call the friendly guys at burien toyota for the part number, i always forget to stash it in a word-document in my computer......23250-46xxx i think it is SW20 MAP sensor. TRE-Performance 255LPH fuel pump. Stock ECU does fine with this MAP sensor/Injector set up. No freak-outs on the timing at all. From what i hear from the local toyota dealer (i befriended some of the Mech's after i stunned them with my build...) they told me the 3S & 5S ECU's are practically the same unit, the MAP signal on both ECU's is designed to read boost as well, AS LONG AS IT COMES FROM THE RIGHT type of MAP sensor. Non turbo MAP sensor freaks out with boost, doing the check-valve trick doesn't really cut it correctly, plus the signal it sends is always off by a few tenths of a volt. SW20 MAP sensor & Supra Injectors are the way to go. QUOTE(presure2) puretone, i actually am using the 2bar map, just out of a alltrac instead of a mr2, same unit tho. QUOTE(puretone) oh ha! i was looking at your pics, i still need to figure this forum out, i musta been looking at your older pics of what seemed to look like the old MAP sensor & 300cc injectors. yeah the 2bar SW20 MAP sensor is the way to go....alltrac 2bar MAP is the *same* thing, altho its listed with a slightly different part number in the Toyota micro-fiches, i dont get why. I grabbed these quotes from presure2's big 5sfte post. hope it helps. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 13, 2007 - 2:33 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) |
uh... so far i've spent 2795USD... which doesn't include a lot of the shipping/reshipping/tax/duties/brokerage i've paid for... i think i got another 1730USD of parts i need 2 spend to hv 99% of the parts
Jan 13, 2007 - 2:37 AM
QUOTE(elvasoshexai @ Jan 12, 2007 - 11:33 PM) [snapback]517553[/snapback] uh... so far i've spent 2795USD... which doesn't include a lot of the shipping/reshipping/tax/duties/brokerage i've paid for... i think i got another 1730USD of parts i need 2 spend to hv 99% of the parts I'm assuming (and hoping) you're using something other than a ct-26? -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 13, 2007 - 6:32 AM
a well built, reliable turbo kit for the 5sfe should cost you ~2500-3k
Jan 13, 2007 - 6:36 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Like a Dutch Celica Forum member always says on our forum. (Which he has quoted from someone else probably)
"Fast, Reliable, Cheap. Pick 2" -------------------- JDM Powerplant installed, BPU coming very soon!
Jan 13, 2007 - 8:42 AM
some guy on celicatech.com is selling his set-up. it's just missing the turbo, map sensor, custom oil and water lines, and few other little tidbits.
Jan 16, 2007 - 11:19 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
i spent 3k+ on mine..
Jan 16, 2007 - 11:33 AM
the way I'm planning to do it now, I expect to spend a little under 2k, hopefully, it might end up at like 2100 by the time it's all said and done.
Jan 16, 2007 - 12:23 PM
Enthusiast ![]() Joined May 5, '06 Currently Offline Reputation: 0 (0%) |
haha i got all my stuff for roughly $500
the turbo, manifold, and dp were $200 from a junkyard, but in great shape, basically no shaft play, and i got the map sensor intercooler and bov $90 side mount from a eclipse GST and a greddy type s, from a friend all the lines for about $25 and injectors off ebay 7mge for $22 with shipping and in great shape all i need now is a fuel pump that i will get from a friend when he gets his new one, and i just have to get the piping and bend it, the exhaust is already done |
Jan 16, 2007 - 8:18 PM
QUOTE(mycelicagt @ Jan 16, 2007 - 12:23 PM) [snapback]518207[/snapback] haha i got all my stuff for roughly $500 the turbo, manifold, and dp were $200 from a junkyard, but in great shape, basically no shaft play, and i got the map sensor intercooler and bov $90 side mount from a eclipse GST and a greddy type s, from a friend all the lines for about $25 and injectors off ebay 7mge for $22 with shipping and in great shape all i need now is a fuel pump that i will get from a friend when he gets his new one, and i just have to get the piping and bend it, the exhaust is already done lucky..... -------------------- -Alex {](O_o)[}
Jan 17, 2007 - 11:59 AM
yeah i know i got really lucky, if i wouldnt have found those parts i would have just bought a 3sgte and done the work to swap in the motor than the turbo kit, but i am still getting the new motor and ill be selling the kit after i get the new motor in
Jan 17, 2007 - 11:12 PM
i guess i overpaid on a lot of my stuff =(
Jan 17, 2007 - 11:28 PM
I picked up a blown 3sgte for $75. So what parts are salvageable off that engine that i could use to turbo my 5sfe? And what else would i need to buy to finish up the kit?
Jan 18, 2007 - 12:32 AM
QUOTE(MaskedMan @ Jan 17, 2007 - 8:28 PM) [snapback]518787[/snapback] I picked up a blown 3sgte for $75. So what parts are salvageable off that engine that i could use to turbo my 5sfe? And what else would i need to buy to finish up the kit? exhaust manifold, turbo, downpipe, oil pan, oil lines, and the 2bar map sensor. though the turbo may need re-built. you're still gonna need: fuel injectors, fuel pump, piggyback unit (like SAFC or emanage), intercooler + piping, gauges (at least a boost gauge), and a blow off valve. probably a couple other small thing too. if you decide you don't want to turbo yours, you could send some of those 3sgte parts my way -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 18, 2007 - 1:10 AM
could someone please take a picture of the 2bar map sensor and tell me where it's located on the 3sgte!? Haha that part confuses the hell out of me, and i have no idea what it looks like haha. Oh any also. The 3sgte injectors wont work? Dammit. Oh well, i'll just grab em next time im at the junk yard. So im looking at another $1400ish to finish up my turbo kit without the turbo rebuild right? And how much as an estimate would it cost to rebuild the turbo?
Jan 18, 2007 - 1:29 AM
the map sensor i got was on the firewall by the passenger side fender, bout a foot away roughly 2 1/2 inches long and 1 1/2 inches wide, i would take a pic of it but my camera doesnt work anymore, and since the 3sgte injectors dont work id try the 7mge supra non turbo injectors, i hear those work great so i got those, check ebay, they are rated at 380 cc, im not sure about a turbo rebuild but i should check into it cuz i should rebuild my turbo
Jan 18, 2007 - 1:38 AM
Thanks man. Well if anyone else has a picture, then that would be great, since i got a whole box of extra 3sgte parts. I might be able to find it in one of them. I got like 3 boxes full of parts.
Jan 18, 2007 - 1:50 AM
go here and scroll down and youll find a pic of the sensor
http://www.6gc.net/forums/index.php?showto...mp;#entry426418 |
Jan 18, 2007 - 2:59 AM
thanks man. I don't even remember seeing that in my Alltrac. Maybe it's lost somewhere hahaha. But thanks, i'll probably just order one at work tomorrow with that part number
Jan 18, 2007 - 3:00 AM
QUOTE(MaskedMan @ Jan 17, 2007 - 10:38 PM) [snapback]518833[/snapback] Thanks man. Well if anyone else has a picture, then that would be great, since i got a whole box of extra 3sgte parts. I might be able to find it in one of them. I got like 3 boxes full of parts. ![]() ![]() EDIT: I just looked how much it would cost new from 1sttoyotaparts.com, and it's like $236... much cheaper to get it used! This post has been edited by 6strngs: Jan 18, 2007 - 3:01 AM -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jan 18, 2007 - 12:49 PM
yeah those buggers are spendy, i got mine from the junkyard along with the turbo, manifold, and downpipe $200 in all
Apr 1, 2007 - 9:07 PM
Enthusiast ![]() ![]() ![]() Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
altogether spent about 1500 on mine...just look around for deals man, and be patient...you can easily spend upwards of 3 g's, but if you take your time and just shop around, you can find stuff cheap
Apr 1, 2007 - 10:35 PM
Enthusiast ![]() Joined May 10, '06 From Somerset Currently Offline Reputation: 0 (0%) |
i can vouch for justin on that i found alot of his stuff on here, alltrac.net, mr2oc, and celicatech. o and of corse ebay! lol. the injectors are hard to find cheap if ur gonna use the rx7 ones. map sensor is the second hardest to get. definatly take your time!!!!
Apr 1, 2007 - 11:29 PM
QUOTE(Cisco93lude @ Apr 1, 2007 - 8:35 PM) [snapback]542195[/snapback] i can vouch for justin on that i found alot of his stuff on here, alltrac.net, mr2oc, and celicatech. o and of corse ebay! lol. the injectors are hard to find cheap if ur gonna use the rx7 ones. map sensor is the second hardest to get. definatly take your time!!!! I already have the injectors and the map sensor. I spent $150 on the injectors and like $65 on the map sensor. so far I've spent $388 (yes I'm keeping track) and I estimate another $1700-2100 more... -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
| Lo-Fi Version | Time is now: August 11th, 2026 - 12:29 PM |
