Jan 17, 2007 - 7:13 PM
Enthusiast Joined Jan 31, '06 Currently Offline Reputation: 0 (0%) |
Ok, so my buddy just got a 94 with a 3rd gen swap. The guy who had it previously removed the w2a and added a front mount, but didnt finish doing all the wiring.
So, what exactly do you need to do electrically with removing the w2a? |
Jan 17, 2007 - 8:03 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(JaxMadine @ Jan 17, 2007 - 4:13 PM) [snapback]518702[/snapback] Ok, so my buddy just got a 94 with a 3rd gen swap. The guy who had it previously removed the w2a and added a front mount, but didnt finish doing all the wiring. So, what exactly do you need to do electrically with removing the w2a? If all the wiring is still in place, you simply need to put short the connection to the level sensor (put a wire across the terminals), and replace the pump with a bulb or resistor... If you are missing the wiring (relay, wiring at the pump), it is a bit more involved. -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jan 17, 2007 - 10:30 PM
ok, that is what i was looking for, thanks a bunch! Now he just needs the JDM hood and front fascia.
Jan 18, 2007 - 9:50 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
-------------------- ![]() Project ST204.5 99.88946% complete... |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 4:18 AM |
