> alarm system, hey guys i have an alarm question
post Jan 28, 2007 - 5:44 PM
bdweber3
Joined Sep 12, '06
From Telford PA
hey guys its me again, i have an alarm question. when i baught my car they gave me an keychain alarm clicker. the one that i have has two buttons the red LED light then under that is a button and under that is anohter button. i know that the top button controls the alarm/disarm. also i konw that holding the top button sets off the panic alarm. but the bottom of the two buttons i dont have a clue what it does. i tired holding it the bottom one and nothing happens (just the red light shows up). does anyone have an idea what the other one does, if so thanks much.
bryan
Replies (1 - 4)
post Jan 30, 2007 - 2:09 AM
forkee
Joined Nov 13, '02
From So Cal
it could be anything or nothing at all. it totally depends on what the installer hooked up on the receiving end of your alarm. since you have tried pressing it different ways with no reactions, then chances are it doesn't do anything. if you want, u can check your alarm box and see if there is an AUX wire that isnt connected to anything. hook it up to a multimeter and press your 2nd remote button. if the needle jumps then you have a winner. next you need to find out if it stays charged until you press the button a second time, or if it returns to zero. you can really do anything you want from hooking it up to a trunk release to turning on lights or radio or popping open a door.
post Jan 30, 2007 - 11:31 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
If it's a Toyota brand clicker, then I know what that bottom button is for. I've posted the manual for our alarm system on this site (in one of my posts) and it says that button is used to allow you to program another car to it. Basically you could just set it up so that button works on your car as well (just follow the instructions for programming a remote in that guide).
post Jan 30, 2007 - 12:27 PM
BluuFire
Joined Jan 4, '06
From Austin, Tx
QUOTE(94GT @ Jan 30, 2007 - 11:31 AM) [snapback]522627[/snapback]
I made my bottom button turn on and off my lights biggrin.gif Although bdweber3 is making it sound like its an aftermarket alarm... in which case its pretty hard to tell if it would do anything without knowing how it was programmed.
This post has been edited by BluuFire: Jan 30, 2007 - 12:28 PM
post Feb 4, 2007 - 1:50 PM
bdweber3
Joined Sep 12, '06
From Telford PA
thanks 94GT got the pdf file and i think it has everything i need and yeah it is a toyota installed system. also bluufire how were you able to get that programmed to your lights? can you do program the button to other things? thanks again
Lo-Fi Version Time is now: September 13th, 2026 - 6:36 PM
