> How come no harnesses work?, After Market Radio Install
post Feb 21, 2007 - 12:03 PM
I3arruka
Joined Feb 20, '07
From The Chi, Illinois
So I am not an expert when it comes to installation, and for every car I've had all I needed to do was buy a harness, wire it to the radio, and plug and play. But the harnesses I have seen do not fit my car at all, am I missing something? (I heard that I needed some type of amp. cord or something)
This post has been edited by I3arruka: Feb 21, 2007 - 12:04 PM
"Pain is weakness leaving the body of the strong"
Replies (1 - 4)
post Feb 21, 2007 - 12:07 PM
Manny
Joined Feb 8, '07
From Oakland, Ca USA
QUOTE(I3arruka @ Feb 21, 2007 - 5:03 PM) [snapback]529025[/snapback]
So I am not an expert when it comes to installation, and for every car I've had all I needed to do was buy a harness, wire it to the radio, and plug and play. But the wires I have seen do not fit my car at all, am I missing something? (I heard that I needed some type of amp. cord or something)
It sounds like you have a factory amp....
You can do 1 of 2 things.
1. reach under your amp and feel for a wiring harness. You should find a harness connected to the amp, and another one plugged into that. Disconnect the harness and pull it around and over the amp. That harness will fit the aftermarket harness that you have.
2. Buy a Toyota/Lexus amp integration harness. most places sell them for like 20 bucks, I have seen them on ebay for like 7 or 8 bucks. If you use this option, make sure that your new head unit has pre-amp rca outputs or it will not work.
Also... If you go with the amp integration harness... (on the harness) make sure that you splice the Blue and Blue with white stripe wires together and connect them to the system remote (usually Blue with white stripe) wire on the stereo harness. The Blue one is so your power antenna works and the Blue/White stripe is so the stereo will turn on your factory amp.
Hope this helps....
This post has been edited by Manny: Feb 21, 2007 - 1:55 PM
-M-
post Feb 21, 2007 - 4:03 PM
I3arruka
Joined Feb 20, '07
[/quote]
So I took pictures but I dont know how to get them on here. I am looking at the amp, and I do not feel anything undernieth it, there is something behind it tho. Should I be worried about disconnecting any important wires accidently? I dont wanna have air bag in my face biggrin.gif I'm gunna take a second look, but does anyone possibly have an exact pic. of what I should be looking for?
post Feb 21, 2007 - 4:55 PM
Manny
Joined Feb 8, '07
Here is a good document on the subject.
http://installdr.com/InstallDocs/Toyota/PDF/869009.pdf
-M-
post Feb 21, 2007 - 8:59 PM
I3arruka
Joined Feb 20, '07
QUOTE(Manny @ Feb 21, 2007 - 9:55 PM) [snapback]529153[/snapback]
Lo-Fi Version Time is now: September 12th, 2026 - 8:58 PM
