> Fixing Highbeam
post Mar 26, 2007 - 3:11 PM
Akira_g4
Joined Mar 15, '06
From Sunnyvale CA
tomorrow im going to attempt to fix my leaking high beam since it blew out like 3 bulbs so far. and what im planning to do is submerge the high beam housing in water, find where bubbles are escaping then reseal that area. my question is will this work? and if so what kind of sealent would work? or is there a better to do it?
Replies (1 - 7)
post Mar 26, 2007 - 3:14 PM
6th_celi_vert
Joined Jan 16, '06
From Kentucky
QUOTE(Akira_g4 @ Mar 26, 2007 - 3:11 PM) [snapback]539991[/snapback]
Unless you remove the glass, you will never be able to get the moisture out if you do that.
post Mar 26, 2007 - 5:08 PM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
Isn't there a hole where the bulb socket goes in?
I think his idea may work.
post Mar 26, 2007 - 10:37 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
just take off the whole lens and reseal it all... I've done it and it works fine.... boiling water and submersion then just pry the lense off... it's not hard at all
post Mar 27, 2007 - 1:11 AM
Akira_g4
Joined Mar 15, '06
From Sunnyvale CA
damn im guessing i cant get around the whole boiling water/ oven technique. i was hopeing there was a way to fix it without using boiling water or the oven. oh well now i gotta find a way to get my mom to let me use her kitchen smile.gif
post Mar 27, 2007 - 7:44 AM
mneal2_92788
Joined Nov 7, '06
From Lawrence IN, 46226
i havta do that soon too, but next week is spring break so ill prolly do it then.
post Mar 27, 2007 - 12:03 PM
Akira_g4
Joined Mar 15, '06
From Sunnyvale CA
yea my spring break is this week and this it probably my one and only chance to fix this. well im going to go work on it in about a hour, ill try gettin pics going to smile.gif
post Apr 4, 2007 - 1:32 AM
dustin15brown
Joined Aug 17, '03
QUOTE(Akira_g4 @ Mar 27, 2007 - 2:11 AM) [snapback]540194[/snapback]
yeah, do you have a heatgun? set it on a lower setting and slowly heat up the glued areas.... and then slowly pry away... I just do the boiling because it's more convenient for me because it allows me to multitask a lot better. When i'm home this weekend and have to remove the JDM high beam lense I will prolly use a heat gun just to be a bit safer
QUOTE(mneal2_92788 @ Mar 27, 2007 - 8:44 AM) [snapback]540229[/snapback]
I'll be home this weekend if you wanna meet up
Lo-Fi Version Time is now: August 2nd, 2026 - 4:19 PM
