> Any one thinkin of converting to a full GT4?, Ebay Clip + driveshaft + rear end
post Apr 15, 2007 - 5:14 PM
Valo666
Joined May 15, '05
From Toronto
I was lookin around on e-bay and found this.
Every thing for a GT4 conversion
Not a bad price for the conversion stuff.
Replies (1 - 6)
post Apr 15, 2007 - 6:08 PM
azian_advanced
Joined Apr 18, '05
From Calgary
not only will there still be a lot of custom fabrication needed for the rear end but it's also missing most of the brake and suspension components..
but still a good price if you're just gonna consider the 3s swap and just sell all the misc parts...
post Apr 15, 2007 - 6:16 PM
rickycillo
Joined Apr 7, '07
From Puerto Rico
what about the rear end?.......just let me know if 94-99 can use the rear end of a 90-93 gt4....because im looking for the rear differential and its components to do mine a gt4
post Apr 15, 2007 - 6:22 PM
tangcla
Joined Jan 22, '06
From Melbourne, Australia
QUOTE(rickycillo @ Apr 16, 2007 - 9:16 AM) [snapback]547001[/snapback]
Rear diff should be the same between the ST185 and ST205.
www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS
15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2
post Apr 15, 2007 - 6:49 PM
post Apr 16, 2007 - 10:09 PM
terqui
Joined May 23, '06
QUOTE(playr158 @ Apr 15, 2007 - 6:49 PM) [snapback]547015[/snapback]
Shipping and taxes alone will add another $1200
post Apr 17, 2007 - 2:07 PM
scothaniel
Joined May 1, '03
From Michigan
The entire subframe is virtually identical - I bolted up the 205 rear end to my 185. I had to swap the 185 lower arms back in as the 205 has a slightly wider rear end the the 185.
Scott
West Michigan
Lo-Fi Version Time is now: September 11th, 2026 - 7:54 PM
