Apr 27, 2007 - 10:32 PM
Enthusiast ![]() ![]() Joined Mar 22, '07 From Greenville NC Currently Offline Reputation: 0 (0%) |
Ok so this morning i get up and take the celi to get the front end aligned and i get some exhaust work done and on the way home my battery light comes on, i am almost 100 percent sure its my alternator seeing as the genius that welded my exhaust pipe didnt disconnect my battery. please correct me if im wrong but has anyone ever heard of the battery light coming on the ST under any other circumstances?
Apr 28, 2007 - 5:30 PM
anyone? also im having some issues getting the alternator off, i dont see any bolts that would be holding it on but how many are needed all together to get it off?
Apr 29, 2007 - 7:43 AM
Enthusiast ![]() Joined Jan 8, '07 From Sunderland UK Currently Offline Reputation: 0 (0%) |
that's why you should always disconect the battery and alternator. It's probably blown the diode pack.
keith |
Apr 29, 2007 - 12:47 PM
so replacing the alt should fix it?
May 1, 2007 - 7:30 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
the Battery Light means that the voltage out of the Alternator is not hight enough to run the car - which means your rectifier? on the Alternator is shot. you can actually replace just that part if you go to a good Starter / Alternator Shop.
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
May 1, 2007 - 9:42 PM
i know theres the swivel bolt, the tightener bolt and there should be one more
May 2, 2007 - 12:00 AM
thank you both, it got it off and back on just fine and the celi is running again
| Lo-Fi Version | Time is now: August 11th, 2026 - 3:20 PM |
