> So bottom line, any turbo kits out there?
post May 3, 2007 - 11:16 PM
GotToyota
Joined Apr 15, '07
From Fort Worth, TX
I know many will say, "make your own kit", but out of curiousity, are there any actually turbo kits made for the 5S-FE on the market?
-Matt
Replies (1 - 8)
post May 4, 2007 - 12:42 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Burien, but their website is down. The kit is way over priced and unreliable like other say. It doesn't come with an intercooler, what kind of turbo kit doesn't come with an intecooler.
94 Celica gt white (sold)
post May 4, 2007 - 3:44 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
any 3sgte turbo kit can be a 5sfe turbo kit
then to complete it you need 440s and a 2 bar map
2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi
post May 4, 2007 - 7:09 AM
QUOTE(NuclearHappineS @ May 4, 2007 - 4:44 AM) [snapback]554030[/snapback]
and a piggy back or stand alone to tune for that.
burien is the only 5sfTe specific kit. its incomplete, over priced, and missing a lot of things. if the idea of doing your own research and buying your own parts turns you off, then your probably not ready to turbo your car.
post May 4, 2007 - 7:36 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
like here's an interesting '5sfe' turbo kit
http://www.koracing.net/viewproduct.php?fo...amp;product=214
you need to add a 3sgte manifold, and to tap your oil pan
Then you need to add your fueling
emanage ultimate + 440s + 2bar map sensor
Then your choice of intercooler + water injection (For high boost)
that's it ... the '5sfte demystified'
post May 4, 2007 - 8:34 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
Sometimes you might be able to find kits on ebay that previous people had on their cars. Not the best way to go, but if your looking for an "almost complete" kit, you might be able to find one on there if you wait around a bit. As with any kit though, your still going to need some of the custom stuff thats required.
ps. i know you dont want to hear it....but imo make your own kit. It will take just as much effort tracking down the parts than it would to try and find an almost complete kit on line. Parts are not that difficult to track down. Start with presure2's post of his turbo...he has everything you'll need to know. I personally couldnt have done it without his info and help.
post May 4, 2007 - 11:08 AM
NuclearHappineS
Joined Oct 17, '04
From St Louis, MO
http://www.lindseyracing.com/mm5/merchant....gory_Code=STORE
post May 4, 2007 - 11:28 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Those are very cool. Wonder how well they work?
post May 4, 2007 - 12:03 PM
DSToyo
Joined Dec 16, '06
From Maryland
i may have missed it but, has anybody here actually done the burien kit before? just curious.
Lo-Fi Version Time is now: September 1st, 2026 - 2:10 PM
