May 7, 2007 - 4:53 PM
Enthusiast ![]() Joined Jan 11, '07 From Rochester, NY Currently Offline Reputation: 0 (0%) |
is there such thing as a left hand drive st205. if so, can you buy the frount cut and transfer the wiring over with it and not have to cut up the harness. thanks JDcelica
-------------------- [img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
May 7, 2007 - 6:24 PM
Enthusiast ![]() ![]() ![]() Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(JDcelica @ May 7, 2007 - 2:53 PM) [snapback]555083[/snapback] is there such thing as a left hand drive st205. if so, can you buy the frount cut and transfer the wiring over with it and not have to cut up the harness. thanks JDcelica -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
May 7, 2007 - 7:54 PM
So the hype about the wiring harness is just to extend it? nothing else needs to be done that requires major work
May 8, 2007 - 3:51 PM
QUOTE(JDcelica @ May 7, 2007 - 5:54 PM) [snapback]555141[/snapback] So the hype about the wiring harness is just to extend it? nothing else needs to be done that requires major work There are a couple guys on here who have done the specific swap you are talking about, so hopefully they can chime in. I did all the wiring for my swap, and adjusted the length of each wire so that the harness looks exactly like it would have if I started with a LHD harness. It took a bunch of time, but I needed to do significant other wiring changes to get the ST205 motor into the Camry, so that was the right route for me. -Charlie -------------------- 2003 Subaru WRX Wagon
May 8, 2007 - 3:56 PM
do you have to extend it because the entry point is on the other side of the fire wall. also how much experience do you think u might need to do the harness because i have so good knowledge of auto mechanics.
May 8, 2007 - 4:02 PM
QUOTE(JDcelica @ May 8, 2007 - 4:56 PM) [snapback]555450[/snapback] do you have to extend it because the entry point is on the other side of the fire wall. also how much experience do you think u might need to do the harness because i have so good knowledge of auto mechanics. if you buy a 2nd gen st185 clip... then you have to rewire everything AND extend the harness. if you buy a 3rd gen st205 clip... then you only have to change a few simple wires, AND extend the harness. if your handy with a soldering gun and have some basic wiring skills with reading wiring diagrams, then you should be able to convert the 3rd gen harness. however the 2nd gen harness is much harder. your best bet is to mail that out to someone and not have to deal with it. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 8, 2007 - 4:17 PM
thanks! what are the chances if I get a st205 clip with the awd componets
also what did you do on your project for the wiring harness? -------------------- [img=http://img56.imageshack.us/my.php?image=signature2fs0.jpg]
May 8, 2007 - 4:48 PM
QUOTE(JDcelica @ May 8, 2007 - 5:17 PM) [snapback]555460[/snapback] thanks! what are the chances if I get a st205 clip with the awd componets also what did you do on your project for the wiring harness? you can buy a clip with the awd setup. i got all that stuff with my 2nd gen clip. but its useless for 99% of the people out there. my rear end ended up going to the junk yard. for my car, i did some of the wiring myself and sent the harness out to dg_performance who helped me with the rest. do more research. these are all very basic questions that have been documented in all the stickies on this site, years ago. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 8, 2007 - 5:02 PM
thanks a bunch. and i know just have been looking around the sight and could not find a nice answer for the wiring harness, because everyone sends them out.
| Lo-Fi Version | Time is now: March 30th, 2026 - 6:32 AM |
