> Boost, Not Passing 1 psi.
post May 22, 2007 - 7:15 AM
Gmoney1
Joined Feb 9, '07
From St.lucia
hey guys , after all my checks and so on ...i still have a boost leak some where ... now the difficult thing is that where i live there are no guys the dynos ...to make it easier .......so how would u guys suggest i find the problem or leak from where it is hiding ?
Replies (1 - 9)
post May 22, 2007 - 7:52 AM
Gary
Joined Aug 28, '04
From FLA USA
Are you sure you have a leak?
If you have that much boost leak, it must be a huge leak.
And if you had a huge leak, your vacuum/idle shouldn't be normal.
What is your vacuum at? How is the idle?
_Gary
post May 22, 2007 - 8:13 AM
Gmoney1
Joined Feb 9, '07
From St.lucia
it is at 10 Vac.
This post has been edited by Gmoney1: May 22, 2007 - 8:13 AM
post May 22, 2007 - 9:14 AM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
you deff have a vac leak you should be sitting between 20-22 at idle
BOOST GETS YOU LAID!!!!
post May 22, 2007 - 1:47 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(jesterwr217 @ May 22, 2007 - 7:14 AM) [snapback]560384[/snapback]
The wastegate might also be stuck open. Does it idle at the normal 650-800rpm?
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post May 22, 2007 - 3:44 PM
Gmoney1
Joined Feb 9, '07
From St.lucia
it sometimes idles at 1000 , then drops down to 800 or lower
post May 22, 2007 - 5:47 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Gmoney1 @ May 22, 2007 - 8:13 AM) [snapback]560370[/snapback]
it is at 10 Vac.
I would suspect the bov. If thats not it you may be loosing pressure around some of the clamps. I would suggest investing in t-bolt clamps. It should be a pretty obvious leak though. But, if its a vacuum leak then the intercooler piping shouldnt have anything to do with it. The leak should be after the throttle body. Try spraying starter fluid or carb. cleaner on the intake. Anywhere it could leak. But try to do this with a cold engine, you dont want a fire! If the idle raises, you found your leak. keep us posted
post May 23, 2007 - 5:51 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
maybe he means 10psi :-P
but yea, if not a boost leak, wastegate stuck open. . .
to NOT hit boost past 1psi, even when flooring it up high...not right
post May 25, 2007 - 6:07 PM
Gmoney1
Joined Feb 9, '07
From St.lucia
well i jus checked my breather hose and that had a big crack in it .. but i have replaced that aleady ......and nope that wasn't the problem
post May 25, 2007 - 6:40 PM
Create a boost leak tester with a air compressor and listen to any leaks and use soapy water to locate anything hard to reach.
Lo-Fi Version Time is now: August 23rd, 2026 - 5:45 AM
