May 23, 2007 - 2:02 PM
![]() Enthusiast ![]() Joined Feb 20, '07 From The Chi, Illinois Currently Offline Reputation: 3 (100%) |
I took a good look at the offset chart, looked through a bunch of topics, and I can't figure everything out so I'm gunna ask so I don't get the wrong parts.
I am getting 17"x7" rims w/an ET 35. What size spacers do I need to make it look flush? (I have stock suspension) ALSO during my search I saw people write different specs for the front and rear, does this mean I need different sized spacers for the front than the rear? Thanks This post has been edited by I3arruka: May 23, 2007 - 2:04 PM -------------------- |
May 23, 2007 - 2:05 PM
That should sit pretty flush as it is. +39 is stock, so it should be fine with +35. If it sits a little sucked in you can use a 5mm spacer.
Some people put more spacers on the back to give it a sort of staggered look, which is what I believe you are referring to with different spacers front and back. This post has been edited by 95CelicaST: May 23, 2007 - 2:06 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
May 23, 2007 - 2:11 PM
Does stock come somewhat staggered?
Thanks for the help -------------------- |
May 23, 2007 - 2:42 PM
Not really, no. If it does it is so small you don't notice it.
| Lo-Fi Version | Time is now: August 9th, 2026 - 3:19 PM |
