May 26, 2007 - 3:23 AM
Enthusiast ![]() ![]() ![]() Joined Jan 6, '06 From Oahu, Hawaii Currently Offline Reputation: 0 (0%) |
I need the whole assembly for the power window DRIVER SIDE. So if anyone is parting out, if you could please take this out for me. It's the Regulator and Motor, which should include all cables and wires. Please let me know.
Thanks Wyatt |
May 26, 2007 - 12:08 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
id test your motor first if you havent already since the regulator can be had separatley and is about $80 new from toyota if your window is just having issues because th cable is fraying then thats the route to go, but if the motor is shot, id try n find something at a u-pull-it type place and just get the whole assembly that way
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
May 26, 2007 - 1:47 PM
Enthusiast ![]() ![]() Joined Mar 13, '06 From Lebanon, Oregon Currently Offline Reputation: 8 (100%) |
Were can you get it for 80?
![]() you cant buy it seperately? Does any have the part number cause I have the same problem and need one asap Mike, -------------------- |
May 26, 2007 - 2:12 PM
Well, the motor is fine, the cable broke, so thats why I need a new one. And instead of having to gut the regulator and motor apart, i think it would be easier to just get it as one big assembly. So yeah, if you guys got one, I need one.
Thanks, Wyatt |
May 26, 2007 - 3:02 PM
if the motor is good, lemme find a part # for you for just the regulator with out the motor, i also have diagrams and procedures i could scan for disassembling the assembly and replacing, not that hard at all, worst part is taking the door apart.
May 26, 2007 - 3:17 PM
Okay, sounds good. But when i took it to my mechanic, he said I should just get the whole thing, but if it is infact easy, then I guess I'll look what you did and hopefully i can save a few dollars
Wyatt |
May 28, 2007 - 9:00 PM
lemme get some stuff printed and scanned for ya about this, hopefully i can have it up online here by tomorrow night
May 29, 2007 - 4:11 AM
Okay cool. Since you seem to know much more than I, I got a question. Will a 96 or 97 assembly fit my 94?
| Lo-Fi Version | Time is now: August 27th, 2026 - 10:51 PM |
