> Turbo on a stock trans ST?, not even sure..
post May 28, 2007 - 12:41 PM
cnelson
Joined Dec 11, '06
From New Jersey
I don't even know if it would be able to done.. i was thinking about turbo-ing my stock 94 st trans (automatic) just run low boost to make sure the trans and engine can handle it.. i was thinking like 8psi would probably be safe what kind of hp and tourqe increase would i see for about 8psi? And how high can i boost with everything stock?
"Drive Well...
...Drift Better"
Replies (1 - 15)
post May 28, 2007 - 4:22 PM
Kadett
Joined Mar 17, '05
From The Netherlands
8PSI using what turbo?
8PSI on a Garret T25 would be alot less then with a T88. As example. Dont think a 7A-FE has enough capacity to turn a T88 around biggrin.gif
post May 28, 2007 - 10:01 PM
cnelson
Joined Dec 11, '06
From New Jersey
well thats my question what kind of turbo would work well on a 7A-FE?
This post has been edited by cnelson: May 28, 2007 - 10:01 PM
"Drive Well...
...Drift Better"
post May 28, 2007 - 10:17 PM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
not to be a dick about it or anything but there is a search button and it does work and theres tons of information on what you would need to turbo a 7A.
but to answer your question a Garret T3 Super 60 would work pretty well. and as for the auto tranny there is a guy on here that has an auto 7afte you should ask him if he had to do anything
-Brian
post May 29, 2007 - 12:51 PM
cnelson
Joined Dec 11, '06
From New Jersey
alright thanks guys.
"Drive Well...
...Drift Better"
post May 31, 2007 - 5:28 AM
cnelson
Joined Dec 11, '06
From New Jersey
does anyone happen to know his username? because i can't find him.. thanks.
"Drive Well...
...Drift Better"
post May 31, 2007 - 5:58 AM
celicaST
Joined Jun 23, '05
oobe and trd94 are a few that come to mind
post May 31, 2007 - 10:21 PM
trd94
Joined Jan 9, '05
From green springs ohio
ok on my last dyno with 15psi and a t3-t4 57 trim (.63 hot .50 cold) and my 370 rc injectors tuned with a safcII i put out 207hp and 214tq on 94 octane the tranni takes it but the tq converter is working over time , i drive it daily so i tuned it down to 10psi and the tq converter works great , the best thing for the tranni is to keep the fluid clean and the tranni cool , i installed a tranni cooler to help with this and i change the fluid in the spring and fall along with a freash filter. i run daily on this setup and it has been almost a year and a half with boost.
This post has been edited by trd94: Jun 1, 2007 - 10:08 AM
post May 31, 2007 - 10:50 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
trd94 talks car nerd very well lol.How do u adjust ur PSI,is it easy or hard as hell?
BANNED. for life, you moron.
post May 31, 2007 - 11:27 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
QUOTE(CelicaST_CALI @ May 31, 2007 - 8:50 PM) [snapback]563651[/snapback]
that has got to be the funniest thing ive read all day! HAHAHA
post May 31, 2007 - 11:30 PM
QUOTE(CelicaST_CALI @ May 31, 2007 - 11:50 PM) [snapback]563651[/snapback]
post Jun 1, 2007 - 12:38 AM
6strngs
Joined May 12, '06
From Wilmington, NC
you just tighten your continuator which is behind your muffler bearings.
post Jun 1, 2007 - 2:00 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE(6strngs @ Jun 1, 2007 - 5:38 AM) [snapback]563686[/snapback]
nonono. thats not the best way to do it.
you have to adjust the magnetic drag control on the turbos compressor housing, which slows the turbine down and makes less boost.
post Jun 1, 2007 - 2:02 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(stephen_lee @ Jun 1, 2007 - 12:00 AM) [snapback]563709[/snapback]
I thought that was the same thing?
post Jun 1, 2007 - 2:18 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
QUOTE(6strngs @ Jun 1, 2007 - 7:02 AM) [snapback]563710[/snapback]
could be?
wht you call it depends where your from
post Jun 1, 2007 - 10:06 AM
trd94
Joined Jan 9, '05
QUOTE(CelicaST_CALI @ May 31, 2007 - 10:50 PM) [snapback]563651[/snapback]
i have a external wastegate with a 4psi spring in it , a manual boost controler to allow me to adjust the pressure going into the wastegate , the lowest i can go is 4psi the highest i can go is 20psi , thats as far as my boost gauge will read wink.gif as far as adjusting the psi all you do is turn a knob on the mbc , not to hard biggrin.gif for us car nerds rolleyes.gif
Lo-Fi Version Time is now: August 4th, 2026 - 3:20 PM
