Jun 7, 2007 - 9:11 PM
is there an easy way of taking these out, without taking the brakes and rotors off?
Jun 7, 2007 - 9:27 PM
my guess is no
Jun 7, 2007 - 9:45 PM
rotors and calipers have to come off Art, after that it's cake.
Jun 7, 2007 - 10:01 PM
i figured as much. now i have to wait till my new rotors come in.
Jun 8, 2007 - 12:10 AM
Enthusiast ![]() ![]() Joined Dec 21, '05 From dallas Currently Offline Reputation: 3 (100%) |
So do we beat the studs out with some WD40? With a hammer or rubber mallet? Does it make a difference?
Jun 8, 2007 - 9:15 AM
you arent gonna get far with a rubber mallet, use a hammer and if you have a aluminum block so it wont mess up the studs but if your replacing them, use a heavy duty hammer...i had to use a sledge hammer when i used to work on deisels
Jun 8, 2007 - 2:15 PM
Enthusiast ![]() ![]() ![]() Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
yea, a mallet will be fine. Theyre actually not that bad to come out.
Jun 9, 2007 - 12:19 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(sugarfree @ Jun 7, 2007 - 10:10 PM) [snapback]566297[/snapback] So do we beat the studs out with some WD40? With a hammer or rubber mallet? Does it make a difference? Yes you do, but before you go postal on the studs with your hammer... you have to remember to move the spindle in position with the half moon cut out on the other side of the hub. Basically, You will only be able to take one out at a time. Alighn the stud with that half moon cut out then hammer it out. Other wise it will hit the the Dust Plate behind it. I know its hard to understand with out pics, but youll see what i mean when you actually take the caliper and rotor off. ill try to get a pic up soon. This post has been edited by eggman40: Jun 9, 2007 - 12:19 AM |
Jun 9, 2007 - 2:17 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
QUOTE(lagos @ Jun 8, 2007 - 4:11 AM) [snapback]566245[/snapback] is there an easy way of taking these out, without taking the brakes and rotors off? Front you only need to remove the Caliper/Rotor In the back (for me anyway because I used 20mm spacers, therefor 20mm longer studs) I also had to loosen the handbrake pads to allow space to move the new studs in and old one's out of course. -------------------- JDM Powerplant installed, BPU coming very soon!
Jun 11, 2007 - 2:47 AM
QUOTE(lagos @ Jun 7, 2007 - 7:11 PM) [snapback]566245[/snapback] is there an easy way of taking these out, without taking the brakes and rotors off? Taking the Rotors and Calipers is actually easier than i thought. When i replace my wheel bearing i took them off... Its just two 17mm bolts that attatch the caliper bracket to the hub and the caliper comes right off. then the rotor follows. The assembly comes off complete with the pads still in place, therefore there wassent any need to push the Pot back in, in order to put the brakes back on. Just hang them from your shock while you work and youll be fine. I was actually surprised how easy it was. Soooo maybe that is the easiest way. beacause im sure you could hammer the studs out with everything on but it would be hard to see if your lined up with the opening in the back. Its just too risky and in my opinion its harder. Good Luck! This post has been edited by eggman40: Jun 11, 2007 - 2:48 AM |
Aug 20, 2008 - 10:44 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
i have some advice to add to this... will update in a lil bit
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Aug 27, 2008 - 9:15 AM
![]() Enthusiast ![]() ![]() Joined Apr 17, '07 From Montreal, QC, Canada Currently Offline Reputation: 1 (100%) |
if you remove the studs, the disc would fall off (the caliper wont really hold it) so how do you wanna remove the studs without removing the disc?
It takes 3 mins and 2 impact sockets to remove the calipers and disc... -------------------- |
| Lo-Fi Version | Time is now: July 30th, 2026 - 7:32 PM |
