> FS: Used Injen Air Filter
post Jun 21, 2007 - 10:53 PM
twitchh17
Joined May 19, '06
From North NJ
anyone interested? will take pics tomorrow. someone could use this as a drop in filter instead of getting a whole brand new intake system. taking best offers.
Replies (1 - 9)
post Jun 22, 2007 - 3:39 AM
daazndood
Joined Jun 5, '06
From Hayward,CA
so it isnt a SRI?
post Jun 22, 2007 - 11:17 AM
twitchh17
Joined May 19, '06
From North NJ
QUOTE(daazndood @ Jun 22, 2007 - 3:39 AM) [snapback]571212[/snapback]
so it isnt a SRI?
no its just the injen air filter itself. u can take off ur stock airfilter box and attach this one.
post Jun 23, 2007 - 12:13 PM
Slick
Joined Jan 10, '06
From Mozambique, Africa
QUOTE(twitchh17 @ Jun 22, 2007 - 6:17 PM) [snapback]571264[/snapback]
so it isnt a SRI?
What's the diameter on the connecting end?
post Jun 23, 2007 - 2:19 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Slick @ Jun 23, 2007 - 10:13 AM) [snapback]571575[/snapback]
so it isnt a SRI?
2.5". same as your throttle body
post Jun 25, 2007 - 7:20 AM
Slick
Joined Jan 10, '06
QUOTE(6strngs @ Jun 23, 2007 - 9:19 PM) [snapback]571595[/snapback]
Cool. Now just one question: if i were to install just the filter, what do I do with the sensor that's connected to the stock filter box?
post Jun 25, 2007 - 10:20 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Slick @ Jun 25, 2007 - 5:20 AM) [snapback]571831[/snapback]
you'd need to install it. you'll probably run rich or lean without it installed and might throw a check engine light. I don't think you should run JUST the filter on there. go get a section of 2.5" pipe (steel, aluminum, aluminized steel, it doesn't matter) with like a 45* 75* or 90* bend (you'll want to measure your engine bay to find out what will fit). drill a hole in the pipe and using the stock rubber grommet, install the air temp sensor. now put the filter at the end of the pipe, and voila easy made short ram.
if you want a full geniune injen intake, I'll have mine for sale in less than a week or so after I start work on my turbo.
post Jun 25, 2007 - 11:06 AM
Slick
Joined Jan 10, '06
QUOTE(6strngs @ Jun 25, 2007 - 5:20 PM) [snapback]571867[/snapback]
Thanks for the tip. Is yours SRI or CAI? Will it fit my 3SGE?
post Jun 25, 2007 - 3:27 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Slick @ Jun 25, 2007 - 9:06 AM) [snapback]571885[/snapback]
it's a SRI, it fits 5sfe's
post Jun 25, 2007 - 4:35 PM
twitchh17
Joined May 19, '06
From North NJ
this isnt for the WHOLE intake system. its JUST for the injen air filter. u can take off your stock air filter and place this one as a drop in.
Lo-Fi Version Time is now: September 3rd, 2026 - 10:44 PM
