Jun 25, 2007 - 7:21 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 30, '06 From Augusta, GA Currently Offline Reputation: 4 (100%) |
So 2 of my 4 spark plug wires aren't going fully in. As in, they don't sit totally flushed with the head. Here's what I mean:
![]() Any ideas why? Do I need to just take it all the way out and then put it back? Is there something wrong with my spark plugs/wires? Thanks for the input. -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Jun 25, 2007 - 9:05 PM
probably blowby..aka your valves are sticking open. Or your plugs arent tightened in fully. I had the same problem. Also check to see if you have any oil in your sparkplug tube, It could be the valve cover tube seals.
edit: whats the milage on the car?/how hard do you beat on it? This post has been edited by Valo666: Jun 25, 2007 - 9:06 PM |
Jun 25, 2007 - 10:17 PM
QUOTE(Valo666 @ Jun 25, 2007 - 9:05 PM) [snapback]572073[/snapback] probably blowby..aka your valves are sticking open. Or your plugs arent tightened in fully. I had the same problem. Also check to see if you have any oil in your sparkplug tube, It could be the valve cover tube seals. edit: whats the milage on the car?/how hard do you beat on it? Mileage ≈ 115k I don't beat on it hardly at all anymore, not since I got my new motor (which was about 6 months ago). How do I check to see if there's oil in my sparkplug tube? -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
Jun 25, 2007 - 10:43 PM
![]() Enthusiast ![]() ![]() Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
QUOTE Mileage ≈ 115k I don't beat on it hardly at all anymore, not since I got my new motor (which was about 6 months ago). How do I check to see if there's oil in my sparkplug tube? Pull your plug wire off. If there's oil in the plug well, there's your answer I had this problem once when I fouled my wires by very intelligently pressure washing my engine and letting water get into the plug well. My #3 wire would just pop itself right back out, even with the engine off. I don't know what caused this, but a new set of wires worked fine. Also, if you haven't changed your wires in awhile you may want to check the contact in the one that's giving you trouble. If it looks damaged, or if it won't "pop" back onto the plug when you put it in, it's time for a new wireset. Other than that, try the above mentioned. Make sure plugs are tight (get them hand tight with an extension and socket, then give a ¼ turn with a ratchet). |
Jun 25, 2007 - 11:16 PM
QUOTE(Delta_Phoenix @ Jun 25, 2007 - 10:43 PM) [snapback]572108[/snapback] QUOTE Mileage ≈ 115k I don't beat on it hardly at all anymore, not since I got my new motor (which was about 6 months ago). How do I check to see if there's oil in my sparkplug tube? Pull your plug wire off. If there's oil in the plug well, there's your answer I had this problem once when I fouled my wires by very intelligently pressure washing my engine and letting water get into the plug well. My #3 wire would just pop itself right back out, even with the engine off. I don't know what caused this, but a new set of wires worked fine. Also, if you haven't changed your wires in awhile you may want to check the contact in the one that's giving you trouble. If it looks damaged, or if it won't "pop" back onto the plug when you put it in, it's time for a new wireset. Other than that, try the above mentioned. Make sure plugs are tight (get them hand tight with an extension and socket, then give a ¼ turn with a ratchet). Will do, thanks guys! -------------------- 2007 Subaru Impreza WRX STi 1974 Datsun 260Z 1997 Subaru Legacy L Wagon Kind of missin' my Celica GT! Hit me up if you're ever in my area. I'm always down for a meet. |
| Lo-Fi Version | Time is now: August 29th, 2026 - 4:28 PM |
