> steering to left when accelerating?, whats causing this?
post Jun 27, 2007 - 7:50 AM
2bcelica
Joined Mar 22, '07
From Murphy, TX
hi - hope you guys can help me out -
i recently replaced all four bearings - front strut mounts - driver side axle - and had a wheel alignment -
- my car is now pulling to the left when accelerating - if i hold the steering wheel firmly then its not really noticeable, but if i hold it freely then it is - I took it to a local shop and they thold me that the front control arm bushings is probably causing the problem -
Is that correct that the control arm bushing could cause this problem? Is this a part that I can replace or do I have to replace the entire control arm (assuming bushing comes with it), because when I searched parts catalog on https://www.1sttoyotaparts.com/partscat.html it does not have it.
Replies (1 - 10)
post Jun 27, 2007 - 10:28 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Check the air pressure in your tires.
**** Photobucket
post Jun 27, 2007 - 10:58 AM
2bcelica
Joined Mar 22, '07
From Murphy, TX
checked and normal - 44 psi on both side
on a side note -- is 3k rmp in 5th gear at 60mph normal -- it seems high to me - would timing fix this
my girlfriends civic is at 2500rmp at 60mph - her's an auto though
This post has been edited by 2bcelica: Jun 27, 2007 - 11:04 AM
post Jun 27, 2007 - 5:25 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
clues any one -
post Jun 27, 2007 - 8:08 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
44 psi seems likes allot, i use 35
post Jun 27, 2007 - 9:11 PM
NaderG
Joined May 13, '07
From riverside, ca
to my knoledge a wheel that is not balanced correctly can cause this , but it also causes vibration so i am not sure....
post Jun 27, 2007 - 11:08 PM
Hanyo
Joined Aug 16, '03
From Bay area
this can also be caused by worn out motor mounts similar to what lagos had.
I hate suspension issues because they are very hard to diagnose without actually driving the car.
post Jun 27, 2007 - 11:42 PM
2bcelica
Joined Mar 22, '07
From Murphy, TX
QUOTE(Hanyo @ Jun 28, 2007 - 4:08 AM) [snapback]573063[/snapback]
tell me about it - i will go ahead and replace all the bushings since i'm getting thumping noises when going over bumps or pot holes - but i'm having a hard time finding control arm bushings at local part stores and online - i'll probably call toyota dealer 2morrow and ask for it -
motor mounts? hmm didn't think motor mounts would be a cause
post Jun 27, 2007 - 11:56 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
QUOTE(2bcelica @ Jun 27, 2007 - 9:58 AM) [snapback]572739[/snapback]
That is normal. That is due to the short gearing of the tranny. Honda's are higher revving engines.
post Jul 14, 2007 - 8:53 PM
94yoter
Joined Apr 27, '07
From Charlotte, NC
this is normal. and use 35 in your tires.
i don't think both wheels get power all the time and when under acceleration it will pull to the left.
post Jul 14, 2007 - 11:44 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
check your rear motor mount. another member reported similar symptoms which went away after he changed his motor mount.
Lo-Fi Version Time is now: September 12th, 2026 - 9:05 AM
