> little help car alarm
post Jun 30, 2007 - 8:44 PM
kamax
Joined Apr 29, '03
From lynn,ma
i am having trouble locating the power door lock/unlock controller. when i open it up, there's a box that says door controller or something but from all the reading i read it is said to be a blue/black wire and a green wire. i was wondering where i can located the wire for the power doorlock? and how thick should it be.. and also the drive kick panel is the panel with all the wiring/plugs for the car right? having a hard time understanding the terms for it. thanks in advance. any help would be a great help... also if you have pictures it'll make my life easier
Replies (1 - 1)
post Jul 1, 2007 - 9:54 AM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
The drivers kick panel is directly to the left of you feet.
The door lock control is to the right of your steering column. You don't need to open it up the wires you need are coming out of it. You are looking for the blue/black wire and a blue and green wire.
When the blue/black wire see a ground the doors lock.
The blue and green both need to be used for unlock but you must use diodes to isolate each wire.
Look in the faq there is a great alarm install article with a section about wiring door locks and it explains the diodes.
Lo-Fi Version Time is now: August 22nd, 2026 - 9:28 PM
