> How do you make component tweeters quieter, MB Quart tweeters too loud
post Jul 7, 2007 - 2:01 PM
san0
Joined Aug 1, '06
From UK - Southern Central
Today I have added a pair of MB Quart tweeters into the plastic housings by the mirrors. The wires are connected straight into the spare speaker wires in the door panel, without crossovers.
So you know, I have some 6.5inch Focal speakers in the doors. The rear speakers are the MB Quart mids (without the crossover attached). The sub is a 12" JBL with amp.
The problem now, is that the tweeters are too loud and i can hardly hear the front mids as it shares the same front signals. How can I control the volume of the tweeters without affecting the front 6.5" speakers in the doors?
This post has been edited by san0: Jul 7, 2007 - 2:28 PM
san0.:GT-SS2:.
Replies (1 - 3)
post Jul 7, 2007 - 2:11 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if they came with crossovers, try running the signal through that, it should quiet it down a bit. and if not, use your treble control. i honestly don't know, since every band has its own amp in my setup (400 highs, 800 mids, 1200 bass)
post Jul 7, 2007 - 2:39 PM
Like stephen_lee said, try using a crossover. It doesn't have to be a MB Quart or Focal crossover necessarily. Or you could use a four-channel amp as your crossover as well.
post Jul 9, 2007 - 12:44 AM
stud97023
Joined Feb 18, '07
From Clackamas, Oregon USA
alright man, a real quick fix to this is to turn down your trebble and adjust your fader to give the rear speaks more power. Then just use your equlizer (should be built into your headunit) and turn down the high freq. BUt if you want a permant fix, then hook up a crossover. You can get used ones on ebay for like 20 bucks
Lo-Fi Version Time is now: July 30th, 2026 - 2:36 PM
