> Bad Smell Fromt Airconditioning
post Jul 12, 2007 - 8:53 AM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
Hey guys i was just wondering if we have some sort of pollen filter that we need to replace from time to time, because im getting an awful wet flower/dead leaves smell when the a/c is on. In my moms 2000 jetta she had a pollen filter and she had to change it when this happend to her?
Thanks
Replies (1 - 16)
post Jul 12, 2007 - 9:45 PM
alltracman78
Joined Aug 9, '06
From Ma
You don't have one.
The system could still have pollen and/or dust in it.
Pick up some AC freshner and spray it in the system.
You can also spray in the cowl on the pass side with the blower on outside air.
This will suck it through the system.
It's really hard to get the smell out sometimes though.
post Jul 13, 2007 - 10:41 AM
NaderG
Joined May 13, '07
From riverside, ca
i have the same dead flower / dead leaves smell in my A/C , my whole car actually , i will pullmy blower motor and clean it soon ... i will do that freshner thing too
post Jul 13, 2007 - 10:50 AM
Redline08
Joined Feb 23, '07
From Albany, NY
pullmy blower motor
Where is that and how do you do it? for the gt, and on the st if you know. Thanks!
post Jul 13, 2007 - 9:37 PM
NaderG
Joined May 13, '07
From riverside, ca
i didnt do it before , but i am pretty sure it is the same for the GT or the ST , according to a couple of posts on here and my repair manual , its located in the area behind the glove box , the glove box is held by some screws ... i will do it some time soon and tell you
post Jul 13, 2007 - 11:08 PM
Redline08
Joined Feb 23, '07
From Albany, NY
sweet thanks
post Jul 15, 2007 - 10:44 AM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
It's probably mold/mildew/bacteria in the ac sysm
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Jul 15, 2007 - 11:09 AM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
yeah... if/when i get motivated enough id like to pull majority of the plumbing out, or at least clean it very well when the dash is apart to have it smell fresh again... mine doesnt smell bad enough for all that, just maybe the first 10-15 seconds when i first turn it on after a while then it goes normal
post Jul 15, 2007 - 10:15 PM
94yoter
Joined Apr 27, '07
From Charlotte, NC
i asked a master toyota tech at work and he said that the smell is from condensation pooled up somewhere and changing the cabin air filter probably wouldn't change it as well as you'd think. i get that smell really bad so i run my ac on the outside air thing instead of recirculate. BG products also sells some stuff that helps.
post Aug 8, 2007 - 10:37 PM
dutchboy
Joined Jun 28, '07
QUOTE(94yoter @ Jul 15, 2007 - 10:15 PM) [snapback]578931[/snapback]
I get that nasty smell when using recirculate, and the A/C doesn't really work in that mode, very warm and humid. A/C Works fine taking air from outside.
Based on this, do you think there is a problem with part of the A/C system, or are my recirculate ducts just clogged or something?
post Aug 9, 2007 - 12:00 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
Um, I had this issue a few years ago. Turns out its not the AC at all. (For me at least)
Check your spare tire tub. I apparently had a improper seal (toyota did not put the seal around some rear wiring. It was there but not placed in the hole.) So when it rained it would drain down into my spare tire well. This caused water to pool up and not drain properly. Stagnant water smells pretty bad and recirculated air made it smell horrible.
After I drilled holes through the plastic drain plugs in the spare tire well and cleaned it out I have not had an issue. I also properly install the wire seal as well.
post Aug 9, 2007 - 12:43 AM
dutchboy
Joined Jun 28, '07
QUOTE(Harold_Fastwaker @ Aug 9, 2007 - 12:00 AM) [snapback]586549[/snapback]
Did you leave the drilled out holes or did you fill back in? If it's not too much trouble, could you take a couple pics of where and what you did? You are talking about the spare tire well in the back right?
post Aug 9, 2007 - 12:46 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE(dutchboy @ Aug 9, 2007 - 12:43 AM) [snapback]586554[/snapback]
Yes in the back. When you take out the tire you will see rubber plugs that are about 2 inch diameter. You can take them out by prying them up.
I took a drill and put 5 holes in it. Made the shape you see on a Dice. That way if water were to get in, it will drain properly. So yes, I left the holes afterward.
post Aug 9, 2007 - 3:54 AM
dutchboy
Joined Jun 28, '07
QUOTE(Harold_Fastwaker @ Aug 9, 2007 - 12:46 AM) [snapback]586555[/snapback]
Where were the wires that didn't have the seal inserted at?
post Aug 9, 2007 - 12:35 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
If you take out the rear interior panel. There is a thick blue wire that connects to a black one. They are for the tails 1 set on each side. The blue wire passes through the body and did not have the seal ring properly placed.
post Aug 10, 2007 - 11:45 AM
ILuvMyCelica95
Joined Dec 16, '02
and yes the blower motor is behind the glove box. I think there are 4 screws that hold it in. Very easy to get in and out. The glove box is also 4 screws.
This post has been edited by ILuvMyCelica95: Aug 10, 2007 - 11:48 AM
post Aug 10, 2007 - 10:03 PM
dutchboy
Joined Jun 28, '07
QUOTE(Harold_Fastwaker @ Aug 9, 2007 - 12:35 PM) [snapback]586651[/snapback]
My seals seemed to be properly installed, and no water in the spare tire well. I will try taking the glove box out and removing the blower motor or spraying a/c system cleaner directly into the blower.
Lo-Fi Version Time is now: June 28th, 2026 - 8:19 PM
