> Any known hub swaps?, Change hub to 5x114?
post Jul 14, 2007 - 12:55 PM
dutchboy
Joined Jun 28, '07
Any known hub assemblies that can be directly swapped onto our celicas so we have a better choice of used wheels?
Buying new wheels is a total waste(70% anyways), and 5x114 seem to be way more common.
Alternateley, what do people think about adapters?
Thanks!
Replies (1 - 7)
post Jul 16, 2007 - 1:03 PM
dutchboy
Joined Jun 28, '07
Looked on ebay, one pair of adapters is $60 plus shipping! Obviously not an option.
post Jul 17, 2007 - 2:31 PM
eggman40
Joined Aug 17, '04
From California
I wondered this exact same thing. i wanted 5x114 Knuckles so i went to the junk yard and i there was a 6gc with no Knuckle and camry which had the Knuckle removed. I took the camry knuckle to the celica and they are very identical but the camry knuckle is just a bit too big! the bolts are spaced wider and therefore would not fit into the lower control arm. Also, the two holes for the shock tower are also spaced wider. Sooo..... no dice, unless you can redrill those holes to fit the celica, but i wouldnt recomend it
i went with a wheel adaptor 5x100 to 5x114. they fit great i got them custom made at www.wheeladaptor.com hope that helped
This post has been edited by eggman40: Jul 19, 2007 - 1:19 AM
post Jul 18, 2007 - 2:10 AM
dutchboy
Joined Jun 28, '07
QUOTE(eggman40 @ Jul 17, 2007 - 2:31 PM) [snapback]579475[/snapback]
How much did they cost you there(for all 4)?
post Jul 18, 2007 - 2:12 AM
eggman40
Joined Aug 17, '04
From California
QUOTE(dutchboy @ Jul 18, 2007 - 12:10 AM) [snapback]579701[/snapback]
I got all 4 with a hub centric lip for like 320 i think
post Jul 18, 2007 - 6:13 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(dutchboy @ Jul 16, 2007 - 1:03 PM) [snapback]579126[/snapback]
How cheap are you trying to go?
Don't you want your wheels to stay on the car?
I doubt you will find a pair of hubs for that cheap [definitely not brand new], never mind the wheel bearings.
They should also be changed if you change the hub.
I wondered this exact same thing. i wanted 5x114 hubs so i went to the junk yard and i there was a 6gc with no hub and camry which had the hub removed. I took the camry hub to the celica and they are very identical but the camry hub is just a bit too big! the bolts are spaced wider and therefore would not fit into the lower control arm. Also, the two holes for the shock tower are also spaced wider. Sooo..... no dice, unless you can redrill those holes to fit the celica, but i wouldnt recomend it
I already told you this in your wheel bearing thread, that is NOT the hub......
The hub is the piece that sits in the wheel bearing and has the wheel studs in it.
The assembly you are talking about is the axle carrier or steering knuckle....
By using the wrong names you gave the wrong advice.....
I don't know for sure if a Camry hub will fit a Celica wheel bearing, but you don't need to worry about it bolting to the strut or lower control arm, all it has to do is fit into the wheel bearing and fit the splined shaft on the outer CV joint.
post Jul 19, 2007 - 1:06 AM
Slick
Joined Jan 10, '06
From Mozambique, Africa
QUOTE(alltracman78 @ Jul 19, 2007 - 1:13 AM) [snapback]579965[/snapback]
I doubt you will find a pair of hubs for that cheap [definitely not brand new], never mind the wheel bearings.They should also be changed if you change the hub.
How much are we talking about here as far as used? If i post a WTB for some used hubs, do you think it would be possible?
post Jul 19, 2007 - 1:17 AM
eggman40
Joined Aug 17, '04
From California
[/quote]
[/quote]
Holy Sh!t your right i completely forgot its the called the Knuckle. Ive called it a knuckle before in other brake realated threads, i dont know what i was thinking this time around.... I didnt notice your post in the write up, i havent seen it in weeks. But ill go back and change it up.
Edit: replied to your post in my write up
This post has been edited by eggman40: Jul 19, 2007 - 1:38 AM
Lo-Fi Version Time is now: September 12th, 2026 - 6:56 AM
