Jul 21, 2007 - 11:01 PM
Enthusiast ![]() ![]() ![]() Joined Feb 23, '07 From Albany, NY Currently Offline Reputation: 3 (100%) |
Im hoping to get new 18s from a friend in about a week or two, he currently has 225/35ZR18 but i want to replace the tires soon, he only has 70% on the front two and like 30% on the back.
I want the no-rubber look without breaking 100ea for the tires. in your opinion what is the best tire size? and is a 38+ offset good? thanks |
Jul 22, 2007 - 12:28 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 28, '03 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
No rubber look? Are you saying you wanna look like you run slicks?
-------------------- NASA/SCCA RX-7....currently under the knife
92 Civic hatch B16 - Sold 10th anniv RX-7 - RIP The Slow Celica - Sold...and then crushed crushed due to street racing. Quote from Seinfeild: George's Boss reading a magazine: "People magazine's most beautiful people. Oh and a Celica...nothin wrong with that!" |
Jul 22, 2007 - 1:14 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
I think he means more like a "low-profile" tire. 225/35/18 is pretty low-profile!
-------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jul 22, 2007 - 1:19 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) |
arent all low-pro's always over 100 bucks a pop?
Jul 22, 2007 - 2:11 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
There pretty low profile. TO low profile in my taste. If you have a 8 or 8.5J rim it would be even lower then on my car (has 7.5J rims)
-------------------- JDM Powerplant installed, BPU coming very soon!
Jul 22, 2007 - 2:23 AM
Enthusiast ![]() ![]() ![]() Joined May 15, '05 From Chicagoland Area Currently Offline Reputation: 12 (100%) |
I have 225/40ZR18 in BFgoodwrench g-force KDW-2's and i love them. The 40's are big enough to give you a little more stability but are not too big. I bent a rim with 35's pretty bad. They are very very low.
Heres a couple pics with the 40 sidewalls on the car. ![]() ![]()
-------------------- Former Celica Owner... RIP 08-2007
Now proud owner of a 2007 Solara w/ TRD exhaust, TRD FTSB, TRD Lowering Springs & many other goodies... |
Jul 22, 2007 - 2:25 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i have 18x8 and i run a 225x35 tires, wouldnt go any lower profile than that, khumo gets you that size for like 68 a piece... imo get something nice im runnin a 28mm offset, so your gonna have 1cm more of the sucked in look than what my car is, given that, the inner rear of the wheel well, theres wheel plastics thats going to rub slightly at full turn if you have an 8" wide wheel with a 225x35< tire, anything less than 90% will be more than fine as far as rubbing, but to answer your question... 215x35 would be ideal... but 225x35 would be perfect!if they will let you... test fit some 235's and see if you can live with any clearence issues that may arise
-------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Jul 22, 2007 - 3:54 AM
QUOTE(beastman @ Jul 22, 2007 - 12:23 AM) [snapback]581036[/snapback] ![]() holy crap! you taking that thing off-roading? it's so fricken lifted! lol -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Jul 22, 2007 - 10:27 AM
QUOTE it's so fricken lifted Yea you need to drop that, drop it like its hot |
Jul 22, 2007 - 10:54 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
i have 215/35/r18s on my 7.5" wide rims and next time im going 225/40/r18 cause with the 35s theres just not enough tire there if you hit a bump or anything.
-------------------- -Brian
Jul 22, 2007 - 11:03 AM
If you want the tyres to be cheaper. I found out that 225/35 tyres are more expensive then the 225/40 tyres because the 35 is a less selling size. 40 is more common. And for ride comfort/handling I would go with the 40 as well.
Jul 22, 2007 - 11:31 AM
would 225/40s have more noticable sidewall rubber than225/35s?
This post has been edited by Redline08: Jul 22, 2007 - 11:31 AM |
Jul 22, 2007 - 11:39 AM
IMO yes. 0.5" thicker sidewall.
Jul 22, 2007 - 11:42 AM
so 40s would be best?
Jul 22, 2007 - 11:58 AM
Definately.
Just compare it to the 17" guys. Example: Defgeph is finally convinced and driving with 45 side's now and most other people (finally) agree that 45 sides are better then the 40 sides for 17" Same goes for our 18" most people use 35 because its closest to the stock tyre. But there is enough room to bridge the gap between what the stock tyres give on speed on the road and what you drive on your speedo. The difference between a 225/45/17 and a 225/40/18 tyre is only 0.5 percent. This post has been edited by Kadett: Jul 22, 2007 - 11:59 AM -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 22, 2007 - 12:02 PM
ok another question, will there be a speedo diff? i read somehwere that diff tires sizes can throw off your speedo by like 5mph
Jul 22, 2007 - 12:10 PM
Yes there is BUT!!! Toyota itself has a gap built into the speedo system. This is so that people cant sue the car maker if driving at exact or just 1 point above the speed limit. This difference could mean a 5-7 percent difference in speed.
The 225/35/18 give a 1.5 difference in speed ( doing 100mph = 101.5mph) 225/40/18 is 5.1 procent. (100mph=105.1mph) I have the 35 in front now and test driven it with help of a local cop (yeah the one's here are friendly) When doing 50km/h (approx 35mph) the laser gun gave a reading of 48km/h. So that would mean that with the 40 side it would be precisly 50km/h. I dont know if there is a tolerance percentage that needs to be deducted from the recorded speed trap in the US? (here in holland thats 3%). All in all, you should be fine. This post has been edited by Kadett: Jul 22, 2007 - 12:11 PM -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 22, 2007 - 12:37 PM
yea i found a website that calculates the speedo difference
friendly cops? no way... LIES!!! lol |
Jul 22, 2007 - 12:47 PM
We dont have cops that give you a hard time here, just because you have a fart can or such. There's not really a import scene here that gets much attention alone because, EVERY car is an import
But this cop is a friend of a friend of a friend of mine -------------------- JDM Powerplant installed, BPU coming very soon!
Jul 22, 2007 - 1:07 PM
im gonna get me a pair of wooden shoes and move to the netherlands! lol
| Lo-Fi Version | Time is now: August 4th, 2026 - 12:16 PM |
