> timing belt
post Jul 29, 2007 - 9:52 PM
Kerr1
Joined Dec 24, '06
From jonesville
Im trying to remove the timing belt and dont wont to mess nething up so i not exactly sure of how to keep the pulleys from rotating....can ne1 show me pix or somthing to get it off....(engine is out of car and only thing on engine is timing belt and exhaust manifold)
Replies (1 - 3)
post Jul 30, 2007 - 3:20 AM
vsideboy
Joined Mar 29, '06
From Hull, UK
as the engine isn't in the car then it should be really easy mate. just stick some tape on all the pulleys at 12 oclock, then when it comes to replace the belt just make sure all the tapes are pointing to 12 and you should be ok.
I wouldn't expect them to move that much anyway.
post Jul 30, 2007 - 10:05 AM
Kerr1
Joined Dec 24, '06
From jonesville
i need to get the whole assembly off tho...pulleys and all....sorry if i didnt make that clear.
post Jul 30, 2007 - 4:06 PM
vsideboy
Joined Mar 29, '06
From Hull, UK
can't think mate, but they will be keyed to the shafts though won't they? if you put a mark or tape on when they are still attached to the engine, then remove them they will only go back on in one position maybe?
not sure if they are just a key to secure them to the shaft or if they are a splined shaft? you could just make sure you have some easily viewable marks for the 12 oclock of the pulleys AND the pulley to the shafts.
Lo-Fi Version Time is now: August 26th, 2026 - 8:13 AM
