> Requesting 3sgte Help, pix inside, Help me figure out where these plugs go
post Aug 11, 2007 - 4:41 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
Hey guys,
I just got my wiring back from Dr. Tweak. I am trying to swap a ST185 3sgte into my OBD2 1997 Celica GT. There are several plugs that I don't where they go. The last mechanic I took my car to put the engine in and never got it running. Messed everything up, so now I have to fix it. Please take a look at these pictures and tell me if you see something wrong and also let me know what these plugs are and where they should go. In the meantime, I will do research and look through old posts to figure it out myself, but if you happen to just know, please post and save me some time. Thank you very much in advance for your help!!
-Anh-Tuan
This post has been edited by CelicaSTX02: Aug 11, 2007 - 4:49 PM
Replies (1 - 11)
post Aug 11, 2007 - 4:52 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
I think #8 (The green plug) is a starter relay from an MR2. I am not sure if that is the right plug to use or not, but I think my last mechanic put that there. I really don't know what he did to the car because he simply didn't ever give me straight answers. His name was MR2GURU from the mr2oc forums if anybody wants to know.
post Aug 11, 2007 - 5:40 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
1. MAP Sensor
2. T-VIS... under intake manifold
3. Knock Sensor... under intake manifold
4. Fuel Injector Resistor Pack... Missing the plug
5. I have a bolt where that sensor is.
6. Water temp gauge
7. Turbo VSV... under intake manifold
8. ?Random Relay?
9. Resistor pack plug for 3rd gen.
10. ?Noise suppressor?
This post has been edited by WannabeGT4: Aug 11, 2007 - 5:40 PM
post Aug 11, 2007 - 8:40 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
QUOTE(WannabeGT4 @ Aug 11, 2007 - 3:40 PM) [snapback]587258[/snapback]
1. MAP Sensor
6. Water temp gauge
8. ?Random Relay?
Wow, thank you very much dude!!!
post Aug 11, 2007 - 9:24 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(WannabeGT4 @ Aug 11, 2007 - 5:40 PM) [snapback]587258[/snapback]
1. MAP Sensor
6. Water temp gauge
8. ?Random Relay?
sounds right to me. The noise surpressor needs to be grounded. I just mounted mine on the back side of the intake manifold.
post Aug 11, 2007 - 11:29 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
Thanx a bunch guys, I hope this will help other people doing the swap later on.
post Aug 13, 2007 - 10:39 AM
make sure you wrap that harness back up before you start connecting everything.
post Aug 13, 2007 - 4:45 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
QUOTE(CelicaSTX02 @ Aug 11, 2007 - 9:29 PM) [snapback]587305[/snapback]
Oh okay, should the car be able to start after I plug everything up? Or is there a next step?
post Aug 13, 2007 - 5:01 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(CelicaSTX02 @ Aug 13, 2007 - 4:45 PM) [snapback]587757[/snapback]
Assuming Dr Tweak did the wiring right and the previous mechanic didn't molest the stock wiring it should fire right up. Is the intake tract complete and sealed? Is the Injector resistor pack wired in?
post Aug 14, 2007 - 1:30 PM
95celgt
Joined Oct 5, '03
From South TX.
how do you ground the noise suppressor? i dont see a way to do it its not like you can put a bolt through it?
btw, that relay goes in your main fuse box...
post Aug 14, 2007 - 3:31 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(95celgt @ Aug 14, 2007 - 1:30 PM) [snapback]587995[/snapback]
there should be a bracket coming off the noise supressor. It may not be or need a ground.
post Aug 15, 2007 - 12:48 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(toyotacrazy @ Aug 14, 2007 - 1:31 PM) [snapback]588018[/snapback]
If it has two wires going to it, it does not need to be grounded (one of the wires is already ground). It should be in the harness near where the ignition coil is located. On my ST205 harness/motor, there is a spot to clip it on the ignitor/coil bracket (that ignitor/coil bracket DOES need to be grounded).
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: August 27th, 2026 - 1:04 AM
