Aug 19, 2007 - 8:41 AM
Enthusiast Joined Jun 6, '07 From Vancouver, BC, Canada Currently Offline Reputation: 0 (0%) |
I've searched the forums and couldnt find any answers to this question:
Do KYB Front Sealed Shocks (334378 Front Right & 334379 Front Left) fit on the 1994's? The KYB catalog shows 95-99 only for the front sealed shock models and inserts for 94-99. |
Aug 19, 2007 - 9:09 AM
Enthusiast ![]() Joined Jul 12, '06 Currently Offline Reputation: 2 (100%) |
QUOTE(iparadox @ Aug 19, 2007 - 7:41 AM) [snapback]589087[/snapback] I've searched the forums and couldnt find any answers to this question: Do KYB Front Sealed Shocks (334378 Front Right & 334379 Front Left) fit on the 1994's? The KYB catalog shows 95-99 only for the front sealed shock models and inserts for 94-99. I think it depends on what type of suspension you have, you need to check your suspension first to find out. If you have the sealed struts then you have the sports suspension, you will definitely need to get the KYB with full strut housing. I forgot the part number though, but I think the year of the car don't matter. |
Aug 19, 2007 - 9:26 AM
Enthusiast ![]() ![]() Joined Oct 19, '02 From Spring Valley, NY Currently Offline Reputation: 1 (100%) |
know where i can get the housing to put the KYB GR-2 inserts??
Aug 19, 2007 - 9:40 AM
QUOTE(Ve1Ls1dEvolutioN @ Aug 19, 2007 - 8:26 AM) [snapback]589090[/snapback] know where i can get the housing to put the KYB GR-2 inserts?? If your looking for OEM, you can order from a dealer, but you can get KYB's that comes with both insert and housing. I believe part #'s are 334378 and 334379. I have a GT and I have these parts installed, can someone confirm if these fit in an ST? Just trying to help out guys. http://www.6gc.net/forums/index.php?showto...orts+suspension This post has been edited by kcizzle: Aug 19, 2007 - 9:43 AM |
Aug 19, 2007 - 11:25 AM
QUOTE(kcizzle @ Aug 19, 2007 - 7:40 AM) [snapback]589092[/snapback] QUOTE(Ve1Ls1dEvolutioN @ Aug 19, 2007 - 8:26 AM) [snapback]589090[/snapback] know where i can get the housing to put the KYB GR-2 inserts?? If your looking for OEM, you can order from a dealer, but you can get KYB's that comes with both insert and housing. I believe part #'s are 334378 and 334379. I have a GT and I have these parts installed, can someone confirm if these fit in an ST? Just trying to help out guys. http://www.6gc.net/forums/index.php?showto...orts+suspension can i buy the housing besides from the dealer?? |
Aug 19, 2007 - 11:55 AM
Enthusiast ![]() ![]() ![]() Joined Apr 24, '07 From lufkin tx Currently Offline Reputation: 0 (0%) |
just curious about the KYB GR2's my boots on the back were completely shredded so i just put on the struts with no boots i knew that the kyb's had a really tight seal on them so should i run into problems ?
Aug 19, 2007 - 4:33 PM
the boots are suppose to block any dirt from getting in the strut or shock
Aug 19, 2007 - 6:49 PM
where can i buy the housing for the KYB GR-2 inserts??
Aug 20, 2007 - 2:47 AM
QUOTE(kcizzle @ Aug 19, 2007 - 2:40 PM) [snapback]589092[/snapback] QUOTE(Ve1Ls1dEvolutioN @ Aug 19, 2007 - 8:26 AM) [snapback]589090[/snapback] know where i can get the housing to put the KYB GR-2 inserts?? If your looking for OEM, you can order from a dealer, but you can get KYB's that comes with both insert and housing. I believe part #'s are 334378 and 334379. I have a GT and I have these parts installed, can someone confirm if these fit in an ST? Just trying to help out guys. http://www.6gc.net/forums/index.php?showto...orts+suspension Yeah I have an ST, will those sealed struts fit my car? |
Aug 20, 2007 - 8:27 AM
yeah i know the purpose of the boot....but i just didn't know if the KYB's are sealed tight enough to run with no boot ? i have heard from a few people that its ok and was just wanting some 6 gen opinion
Aug 20, 2007 - 9:18 AM
dirt will wear your shock down quicker, so you might as well invest in $10-20 a boot
Aug 20, 2007 - 3:10 PM
yeah i just ordered some KYB strut boot from "http://www.importrp.com/home"... its $13.50 each boot plus S/H...the cheapest one i found
Aug 20, 2007 - 11:39 PM
i know but i thought that they were tight enough to be able to go uncovered?....i couldnt wait on a boot and i had to get it done....
as they say do it half way the first time and right the second |
Aug 21, 2007 - 8:29 AM
i hope it makes a difference...this is my 3rd set of shocks in 7 years...LOL
Aug 22, 2007 - 11:44 AM
QUOTE(Ve1Ls1dEvolutioN @ Aug 21, 2007 - 1:29 PM) [snapback]589639[/snapback] i hope it makes a difference...this is my 3rd set of shocks in 7 years...LOL I called up KYB and they said that the sealed shock DO fit the 1994 ST. Call up your local Toyota parts department first to confirm your car (by VIN #) has the following OE numbers: Left - 48520-80045 Right - 48510-80219 If so you can use the sealed struts that KYB offers for '95's. |
Aug 22, 2007 - 2:44 PM
QUOTE(iparadox @ Aug 22, 2007 - 9:44 AM) [snapback]589929[/snapback] QUOTE(Ve1Ls1dEvolutioN @ Aug 21, 2007 - 1:29 PM) [snapback]589639[/snapback] i hope it makes a difference...this is my 3rd set of shocks in 7 years...LOL I called up KYB and they said that the sealed shock DO fit the 1994 ST. Call up your local Toyota parts department first to confirm your car (by VIN #) has the following OE numbers: Left - 48520-80045 Right - 48510-80219 If so you can use the sealed struts that KYB offers for '95's. thanx for looking it up for me...but i just bought the KYB GR-2 on ebay with the inserts...i need just the housing....where can i get them?? thanx for your help |
| Lo-Fi Version | Time is now: May 24th, 2026 - 6:27 PM |
