> 5s tranny axles keeps poping out
post Aug 22, 2007 - 12:17 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
well i have a 3rd gen 3s swap and is using the 5s tranny but some how the long shaft axles keeps poping out anyone have a clue why..need help.. im not using the braket that holds the the long shaft to the motor cause the 3rd gen 3s doesnt have the bolt holes to have the braket there. anyone with a 3s and is using the 5s tranny please let me know how yah made this work thanks
Replies (1 - 3)
post Aug 22, 2007 - 1:40 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE(RUNNIN-LOW @ Aug 22, 2007 - 5:17 PM) [snapback]589935[/snapback]
r you saying that ur not using any thing to hold the carrier bearing in place??? because thats what usually holds the axle into the tranny.
my 3rd gen 3s had holes to mount the carrier bearing assembly. I just had to take one of the two supports off for the intake manifold.
ive been having trouble with axles on the s54 trans and 3s set up. the length between the trans and the carrier bearing all are fine but the my axle between the carrier baring cv joint and the hub seem to be to short. This resulted in my cv joint giving out and coming apart.
reasonably thinking about it the s54 trans is still using the same s54 mounts and thus should be in the same spot as it was with my 5s. so i know its the fact that ive just been getting the wrong axle from autozone.
This post has been edited by urbandork: Aug 22, 2007 - 1:42 PM
post Aug 22, 2007 - 5:21 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
2nd and 3rd Gen should both have provisions for the carrier bearing bracket. Like urbandork said, you have to remove an intake manifold support to use them.
post Aug 22, 2007 - 7:39 PM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
thanks ill check that out im not sure if i even still have that part but yeah it still worked out fine..great i just lost like 40bucks worth of gear lube haha..thanks yah
Lo-Fi Version Time is now: September 11th, 2026 - 8:40 PM
