> Cleaned engine now its f(*_ed
post Aug 22, 2007 - 8:42 PM
celi2nv
Joined Jun 11, '07
From wilson nc
SO i washed my engine with a presure washer at the car cleaning place eny way it started was cool for like 3 secs then ****ed up i think its the spark plugs it runs i drove it home b ut its running on 3 clinders i already checked the wires eny eny one got eny clues
Replies (1 - 10)
post Aug 22, 2007 - 9:26 PM
trdwasiq
Joined Aug 15, '07
From ATLANTA
same thing happned to my other celica:) keep running it until water dry out
KEEPIN IT LOW... WAP PRODUCTIONS... www.myspace.com/waprod
post Aug 22, 2007 - 9:39 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
QUOTE(trdwasiq @ Aug 23, 2007 - 2:26 AM) [snapback]590042[/snapback]
i woulod NOT keep running it
i did that to my old honda and it broke the crank
wait for some others to put their ops in first
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Aug 22, 2007 - 10:44 PM
start by typing "any" not "eny"
remove you spark plugs let the cylinders air out (replace them)
remove your distributor cap/rotor make sure all that is dry on the inside.
did you bother to cover/protect key electrical components?
or did you just spray willy nilly?
post Aug 22, 2007 - 10:45 PM
dry under the distributor cap.
post Aug 22, 2007 - 11:04 PM
Lexicon_Devil
Joined Aug 22, '07
From Downriver, Michigan
I would do exactly what player158 and Bitter said. I wouldn't run it until you've done both.
Have you checked your distributor cap in the dark for cracks? I had one in my old CRX that
was so bad, the car would stall out if it was too humid out.
My new, blue spark plug wires gave my Celica, roughly, 250 more horsepower..
94 Celica GT
89 Sentra Sport Coupe Project (the other haggard woman)
post Aug 22, 2007 - 11:50 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
do exactly what playr said do not start it till everything is replaced and dry then change ur oil its gona look like milk
BOOST GETS YOU LAID!!!!
post Aug 23, 2007 - 12:42 AM
FortuneCookie
Joined Dec 12, '06
From Fob Sharana, Afghanistan
Dude, you're suppose to COVER UP the intake filter and ANYTHING electrical before you pressure wash. That means distributor, alternator, battery, etc. If they get wet, they will indeed start to crap out on you. And if you didn't cover up that intake filter, your car might be on hydrolock too.
post Aug 23, 2007 - 7:07 AM
if his car hydro locked it wouldn't run period, and if he tried to run it would have found himself w/bent valves, and really not running.
secondly NEVER EVER NEVER EVER use a PRESSURE washer on your engine.
NOBODY should need to do this
follow this procedure
1. Let the engine run for a minute or two to warm it up. Grease and other gunk is easier to remove when the engine is warm (NOT HOT).
2. Cover any exposed electrical components and anything else you do not want to get a bunch of water on with aluminum foil.
3. Get a can of engine degreaser from your local auto store...they used GUNK Engine Degreaser. Spray it liberally on everything! Don't be shy...they used the entire can. Let is sit for 10-15mins so it can breakdown and loosen all that grime.
4. Get the hose out and spray down everything to remove all the degreaser and dirt and grime. Do not use a nozzle...just the hose is enough pressure. You do not want to blast water into all the engine components...especially on newer cars.
5. Let the water run off for a few mins and start the engine and let is run for 30 seconds to help dry some of the water.
6. Here's the final step spray the entire engine bay down with WD-40. use an entire can and spray it on EVERYTHING! Some substitute Pledge furniture spray instead of WD-40 (believing WD-40 attracts dust).
This post has been edited by playr158: Aug 23, 2007 - 7:08 AM
post Aug 23, 2007 - 9:08 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
7AFE is not an interferance motor, meaning the valves will not hit a piston if motor jumps time.
post Aug 23, 2007 - 9:39 AM
FortuneCookie
Joined Dec 12, '06
QUOTE(playr158 @ Aug 23, 2007 - 8:07 AM) [snapback]590117[/snapback]
Not entirely true. There was a time when I totally forgot to cover my intake and got it wet and totally forgot about it. I drove him with it barely working on me but never really shut off. I just ramm the crap out of it to get all the water out of the engine. Was probably minor water or wutever that was left on the intake filter after I finished pressure washing.
Lo-Fi Version Time is now: September 11th, 2026 - 11:22 PM
