> help plz evil stock suspension
post Aug 24, 2007 - 12:11 PM
Vissi
Joined Jun 6, '06
From Cedar Hill ,Texas
Well i finally got around to putting on my stechs and my kyb's today. Well i started atleast.
Is the top bolt on the struts saposed to move the whole strut? I cant seem to get it off because when i try to take it off, the silver metal piece in the middle of the strut moves with it, along with the cap. Surely theres a trick to it or something XP.
Thanks
-dave
0111011001101001011100110111001101101001
Chrome wont get ya home
Replies (1 - 12)
post Aug 24, 2007 - 12:25 PM
put the suspension back on the car. attach the top 3 nuts to hold the assembly in. (no need to do the bottom)
loosen the large center bolt first till you have a few threads left.
remove from car
you should be able to pop it off pretty easy from this point.
just be careful the spring = potential energy, when the nut comes off it will go POP...and shoot the nut ~12 inches away.
post Aug 24, 2007 - 12:45 PM
Vissi
Joined Jun 6, '06
i attached em but still no luck. this is the part that is moving.
post Aug 24, 2007 - 12:54 PM
yea i know that part, your's probably slipped outta its slot.
the shaft @ the top isn't a full circle where the threads are its more like a "D" shape so that it seats into the tophat and doesn't spin.
since yours is spinning (like OEM VW) you'll need air tools/electric impact
to get it off, or figure out how to get it seated back correctly.
post Aug 24, 2007 - 1:00 PM
Vissi
Joined Jun 6, '06
damnet, i used all the money i had buying new tires and these shocks, o well i guess itl have to wait till a later time.
thanks for the help
This post has been edited by Vissi: Aug 24, 2007 - 1:00 PM
post Aug 24, 2007 - 1:03 PM
could you do a favor. take a picture of the VERY TOP (birds eye view)
of the KYB strut and post it?
This post has been edited by playr158: Aug 24, 2007 - 1:03 PM
post Aug 24, 2007 - 2:39 PM
Vissi
Joined Jun 6, '06
Would using spring compressors help at all maybe?
I was just thinking that maybe if i compressed the spring that i could adjust back on the strut mount. Feasible?
This post has been edited by Vissi: Sep 19, 2007 - 3:53 PM
post Sep 19, 2007 - 3:54 PM
Vissi
Joined Jun 6, '06
Bump for a new idea ^^^
post Sep 19, 2007 - 4:31 PM
Harold_Fastwaker
Joined Aug 8, '07
From United States
QUOTE(Vissi @ Sep 19, 2007 - 4:54 PM) [snapback]597373[/snapback]
Any way for you to clamp the inner tube so it cant move? Make sure you wrap it with something thick so it does not receive any digs.
post Sep 21, 2007 - 10:00 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
if the top of the strut isnt lined up with the mount its gonna keep spinning, there is a shape you gotta fit in...looks like [)
post Sep 21, 2007 - 10:22 AM
QUOTE(playr158 @ Aug 24, 2007 - 1:54 PM) [snapback]590425[/snapback]
^put it together correctly.
post Sep 21, 2007 - 1:01 PM
eggman40
Joined Aug 17, '04
From California
I got mine out with an impact gun. if try other methods and still cant get it off, as a last possibility, i would look for the nearest shop that has an impact gun, have them break it loose... then tighten it a little bit with a ratchet, then slowly drive the car home. WHen you get home you should now be able to just break it loose with your ratchet. then take it back for them to tighten it with the gun again.
post Sep 22, 2007 - 4:28 PM
coldbluesteel
Joined Jul 9, '04
From Las Vegas USA
I don't know a shop in the world that will let you drive out of there like that... not safe.
If your gonna go to a shop just take the struts and coils with you ask the guy for a little help, and if he's nice he'll do it for six pack or $20. Don't get yourself killed please. The best way to do stock springs is to use a spring compressor... period. Aftermarket, you can switch and swap no problem.
Lo-Fi Version Time is now: May 15th, 2026 - 9:54 AM
