Sep 2, 2007 - 1:14 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 25, '03 From Miami, FL Currently Offline Reputation: 9 (100%) |
Tried searching the manufacturer's site and google with no luck. I found tirerack has an article on correct inflation but I'd rather go by an official number rather than looking at it. I'm thinking 32psi, but I dunno. Please let me know what's the correct inflation pressure on these tires.
Sep 3, 2007 - 2:52 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
on my set i think it says 45 psi right on it
i know the number is on there just gotta look for it. -------------------- -Brian
Sep 3, 2007 - 8:11 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
to get full use out of tires use what is put on the tire
Sep 3, 2007 - 9:15 AM
i run 35~40 psi in mine
This post has been edited by playr158: Sep 3, 2007 - 9:15 AM |
Sep 3, 2007 - 7:46 PM
well the tire says max 44psi. id rather not max em out.
Sep 3, 2007 - 11:48 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i run 225 35x18 and i keep mine around 38-40 as best as i can, have toyo t1r's with about 19-20k on them and still about 6.5-7 of tread left via depth gauge
i also hear its a good idea to keep the pressures equal across the car like run 38 & 38 for the fronts, and for longer trips, 45 & 45 in the back for better millage, warm temp pressure that is. but its not goo to have the fronts be like 28 on the drivers and 35 of the passengers. -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Sep 5, 2007 - 7:49 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
Go for around 40 psi if it says 45 or 44.
-------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
| Lo-Fi Version | Time is now: August 4th, 2026 - 11:22 AM |
