> Headgasket
post Sep 26, 2007 - 10:12 PM
95celgt
Joined Oct 5, '03
From South TX.
Hey guys, i was wondering if all headgaskets are the same? in bore size i mean, im looking into buying a metal head gasket and want to know if i need to specify that my block is bored 20 over (.020). I think im gonna buy an ACL one (the people that make bearings ;p) so can someone be so kind as to telling me what I have to torque the head bolts to? also should 1mm thick be fine or should i get a thicker one?
Replies (1 - 10)
post Sep 27, 2007 - 6:07 PM
95celgt
Joined Oct 5, '03
From South TX.
waiting........:-(
post Sep 28, 2007 - 8:09 PM
alltracman78
Joined Aug 9, '06
From Ma
HG have a slightly larger bore than the cylinders to allow for overboring.
As for how thick you need, that depends on what C:R you want.
Keep in mind if the head and/or block have been machined this will lower your C:R.
The head bolt torque will also depend on what HG you use and what head bolts you use [might as well get studs if you're tearing into it].
post Oct 3, 2007 - 9:12 AM
95celgt
Joined Oct 5, '03
From South TX.
Anyway you can piont me to where I can buy one other than ebay? Thanks:)
post Oct 3, 2007 - 4:22 PM
Punch
Joined Jan 29, '04
From Brooklyn moved to Miramar Florida
most 3S-GTE hae gasket com 88MM that should be good even if you went 60 over the stock bore...
post Oct 4, 2007 - 4:20 PM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
Out of curiousity what are the differences between 5S-FE and 3S-GTE headgaskets. Can they be interchanged (i.e. can you use a 3S-GTE head gasket on a 5S-FE without modification?)?
Anyone have pictures comparing the heads, blocks, gaskets of the two engines?
post Oct 5, 2007 - 11:15 AM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE(WALKER @ Oct 4, 2007 - 5:20 PM) [snapback]601703[/snapback]
^ no they are not interchangable.
3sgte = 2.0l
5sfe = 2.2l
cylinder diameter is different, so there for the HG has a different hole diameter.
Kawi Love
post Oct 5, 2007 - 12:31 PM
WALKER
Joined Mar 29, '06
QUOTE(devilsden97 @ Oct 5, 2007 - 10:15 AM) [snapback]602046[/snapback]
3sgte = 2.0l
5sfe = 2.2l
Well the 3S head can go on the 5S block. The cylinder bore is 86mm (3S-GTE) vs 87.1mm (5S-FE), therefore if the gasket bore is 88mm, I would think it would work on both. Just curious, that is why I would like to see a picture of a 3S head or gasket and a picture of a 5S head or gasket.
post Oct 5, 2007 - 4:55 PM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(alltracman78 @ Sep 29, 2007 - 1:09 AM) [snapback]599957[/snapback]
I thought machining those two would increase C:R. (that's what you must have meant)
QUOTE(WALKER @ Oct 5, 2007 - 5:31 PM) [snapback]602085[/snapback]
3sgte = 2.0l
5sfe = 2.2l
Makes sense for the 3s HG to go on a 5s block.
Pics would be nice, (if only ice with his 5s-gte had some pics of the diff. HG)
CLOSED on 25 acres!
-shop coming soon....
post Dec 18, 2007 - 4:10 AM
Turbofun
Joined Dec 11, '07
From Norway
Any headgasket that's interchangable for the 7A-FE ?
Or any know who that sells reinforced ones for this engine?
post Dec 18, 2007 - 6:35 AM
QUOTE(Turbofun @ Dec 18, 2007 - 4:10 AM) [snapback]623807[/snapback]
toyota sells a metal headgasket for the 7a.
the 3s and 5s gaskets are not interchangeable because of the water jackets in the gasket dont line up from motor to motor.
Lo-Fi Version Time is now: May 17th, 2026 - 10:54 PM
