> is it too old?
post Oct 8, 2007 - 2:17 PM
Element
Joined Apr 16, '04
From Raleigh, NC
i'm thinkin about puttin a turbo on my 5sfe...but it has 158k miles...
compression is rather high on all 4 cylinders...b/t 190-205 on them all
doesn't burn oil (spark plugs are clean as a whistle...) just a bad rear crank seal causing a leak
should i go for it? any things i really need to consider?
Replies (1 - 10)
post Oct 8, 2007 - 3:15 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
might want to change the headgasket and timing belt beofe you do anything. otherwise go for it.
post Oct 8, 2007 - 3:39 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
I turbo'd mine with 150k and i have had no problems so far
post Oct 8, 2007 - 7:38 PM
frosty
Joined Sep 1, '04
From Alabama
CLOSED on 25 acres!
-shop coming soon....
post Oct 8, 2007 - 8:53 PM
change the question from "is it too old?" to " can i afford to do it right?"
post Oct 9, 2007 - 6:10 AM
Element
Joined Apr 16, '04
From Raleigh, NC
just changed the timing belt about 5k miles ago...
planning on pulling the head in december to decarbonize the cylinders...nice metal head gasket then...
money is always the kicker isn't it? that's why i'm tryin to research and get stuff now, thanks everyone
post Oct 9, 2007 - 8:19 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
QUOTE(frosty @ Oct 8, 2007 - 8:38 PM) [snapback]603074[/snapback]
why not? lol
post Oct 9, 2007 - 10:03 AM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(jcaron9gt4 @ Oct 9, 2007 - 1:19 PM) [snapback]603228[/snapback]
why not? lol
CLOSED on 25 acres!
post Oct 11, 2007 - 11:25 PM
6strngs
Joined May 12, '06
From Wilmington, NC
I just turboed mine with the same number of miles, 158K, and the only thing that went wrong that wasn't my own fault was the rear crank seal going out. so if you just replaced that then you should be good tongue.gif
post Oct 12, 2007 - 2:00 PM
Element
Joined Apr 16, '04
From Raleigh, NC
gonna replace it when I do my engine work/turbo install in December biggrin.gif
post Oct 12, 2007 - 2:14 PM
6strngs
Joined May 12, '06
From Wilmington, NC
oh, well, I'll just let you know now it's a bit*h.
if you're getting an aftermarket clutch (and you should be if you're doing a turbo) then do the seal at the same time.
This post has been edited by 6strngs: Oct 12, 2007 - 2:16 PM
Lo-Fi Version Time is now: September 19th, 2026 - 6:21 AM
