> ACT Hybrid Clutch Part Number, Custom Made 6-Puck Sprung Clutch
post Oct 13, 2007 - 3:19 AM
PhilipK
Joined May 4, '07
From Beaumont
I just got my special order ACT 6-Puck Sprung Hybrid clutch. This allows the GT transmission to mate with the ST205 3sgte. I know that there has been problems with the SPEC hybrid clutch, so if you would like to try ACT, all you have to do is call them and give them the part number. Its a new number, this is the first time they have made this disc. The disc is rated for 400-500 torque. KO Racing uses the ACT plates for their high horsepower applications, with very good results. All ACT products are made in house and are very high quality. Once installed and broke-in I will give my review.
6236216 - ACT 6-Puck Disc - $180.00 http://www.advancedclutch.com
T023 - ACT Heavy Duty Pressure Plate - $256.00 http://www.autocom.com/catalog
AT17 - ACT Alignment Too - $5.00 http://www.advancedclutch.com
31230-32060 - OEM Release Bearing - $38.00 http://www.1sttoyotaparts.com
It would be nice to sticky or put this info somewhere so everyone has a chance to read it.
Replies (1 - 6)
post Oct 15, 2007 - 7:53 PM
PhilipK
Joined May 4, '07
From Beaumont
Does no one care about this?
post Oct 16, 2007 - 12:36 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Cool. Should work for 2nd gen 3SGTE as well. Is the clutch disc the spring centered or a solid hub design?
post Oct 16, 2007 - 3:32 PM
PhilipK
Joined May 4, '07
From Beaumont
Yes, its sprung as I said and it will work on a 2nd gen.
post Oct 16, 2007 - 9:59 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(PhilipK @ Oct 16, 2007 - 3:32 PM) [snapback]605518[/snapback]
Sprung or unsprung will work with any 3sgte - its a matter of torque holding capacities and drivability.
post Oct 16, 2007 - 10:02 PM
unsprung = teh suck.
post Oct 16, 2007 - 10:19 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(lagos @ Oct 16, 2007 - 10:02 PM) [snapback]605659[/snapback]
For a street application, they are more difficult to modulate. However, they won't have a tendency to chatter like some sprung clutches (e.g. spec) and are the next step up when sprung clutches won't cut it due to power levels. It all depends on your application.
If I were getting another sprung clutch, it would be clutchmasters for sure. Everything that I have read about Act is that they are solid, good products but have a much stiffer pedal feel. I can't speak for others, but having a stock-like pedal feel is important to me in a street car.
Lo-Fi Version Time is now: September 19th, 2026 - 12:49 AM
