> Popping noise after springs and struts install.
post Oct 18, 2007 - 7:21 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So I just got done installing my sprint springs and kyb struts. When I turn my steering wheel all the way to the left or right I get a popping noise from the front driver side. What do you think went wrong?
94 Celica gt white (sold)
Replies (1 - 13)
post Oct 18, 2007 - 7:24 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Did you grease everything up when you put it all back in? If not, you'll get popping and pinging as you turn the wheel.
**** Photobucket
post Oct 18, 2007 - 7:28 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I just greased down the top mounts. What else is there to grease?
post Oct 18, 2007 - 7:30 PM
95CelicaST
Joined Feb 5, '05
Did you mount the spring in properly? There is a specific way the spring needs to sit, or else it will spin around until it seats itself.
**** Photobucket
post Oct 18, 2007 - 7:33 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I seated it in the groove right. Maybe I moved it around a lot after my axles kept poping out. Hmm. well is it bad for it to seat itself?
post Oct 18, 2007 - 7:39 PM
95CelicaST
Joined Feb 5, '05
Its not "bad", but I would definately get in there and check it out. You don't want that to continue. If it were coilovers it would be different.
**** Photobucket
post Oct 18, 2007 - 7:48 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Alright I'll check it tomorrow, thanks for the info man.
post Oct 18, 2007 - 7:51 PM
Valo666
Joined May 15, '05
From Toronto
it could be your mount bearings. Mine had the same problem. bearings are like $40 new from Toyota
post Oct 18, 2007 - 8:00 PM
Jared95
Joined Apr 24, '07
From lufkin tx
popping is kinda normal alot of people that installed springs told me they experienced the noise and i did to it takes about 3 days or so and it will stop they just need to settle? correct me if im wrong though??
post Oct 18, 2007 - 8:12 PM
95CelicaST
Joined Feb 5, '05
Right, popping can be normal within a certain time frame. This is from the springs fully seating themselves and settling in, but if it continues there is something that needs to be addressed.
**** Photobucket
post Oct 18, 2007 - 8:36 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
OKay, well I'll just give it about 2 days. If it continues I'll check it out.
post Oct 18, 2007 - 8:39 PM
uberschall
Joined Jul 29, '03
From north of detroit
if you didn't torque all the mount bolts (esp the lower ones) to spec, they can actually move. if you torqued them all i wouldn't worry about it, but i've seen it happen before.
do you know who i am, mr. worley?
post Oct 18, 2007 - 8:41 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
all torqued like theres no tomorrow.
post Oct 18, 2007 - 9:53 PM
Jared95
Joined Apr 24, '07
From lufkin tx
oh yeah they pop especially bad on the first day right after you put them on...its scared the crap out of me too when i first heard it
Lo-Fi Version Time is now: September 12th, 2026 - 12:18 AM
