> Different Rear Subframe?, GT and ST
post Nov 8, 2007 - 3:35 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Since I'm finally getting my exhaust done, and was debating over under/over axle exhaust, I took a look at the rear subframe.
From what I can see is the GT models have a 'holding plate' or somesort on the subframe to hold the suspension arm bolts.
Take a look
Pictures from lagos (GT) rear subframe:
Picture from 95CelicaST
Can anyone ellaborate about this, just curious. Will go to Mr T in the morning to check the EPC.
Replies (1 - 12)
post Nov 8, 2007 - 3:46 PM
94celigts
Joined Jun 13, '07
From Whitby, ON, CAN
im not 100% but it looks the same just missing that bracket in the middle of the crossmember but it looks as if it was removed on the yelli celli. ??
post Nov 8, 2007 - 3:48 PM
Kadett
Joined Mar 17, '05
QUOTE(94celigts @ Nov 8, 2007 - 9:46 PM) [snapback]612368[/snapback]
It looks like that yeah, but on every ST I've seen (just take a look at the ST exhaust topic) it doesn't have it, and on every GT it's there. (On mine, Lagos, another Dutch GT owner)
post Nov 8, 2007 - 3:53 PM
94celigts
Joined Jun 13, '07
oh interesting enough. i never knew that... maybe its some un-needed weight our fat GT's can spare to lose.
post Nov 8, 2007 - 7:38 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(94celigts @ Nov 8, 2007 - 12:53 PM) [snapback]612373[/snapback]
or it could stiffen up the rear end for better handling?
post Nov 8, 2007 - 7:53 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
have you had any issues with scraping? I've been kicking around redoing my exhaust.. the Greddy one has pretty much seen it's better days and it time to bump it up for the 5sfte project. however I can't decide if I wanna run under or over the axle. thought if I could cut out a little bit of the spare tire area and weld in a new piece of sheet metal I could get 3 inch in there. But if it can fit under the axle that makes life alot easier =)
Guess my ?'s are
what size pipe did you use?
is your car lowered, if so how close does the exhaust sit to the ground?
thanks
Matt
99 project version 3.0.. hello SEMA 2010 =)
post Nov 8, 2007 - 10:46 PM
1bwilson
Joined Aug 30, '02
From Maryland
Im about 99% sure you can get a 3 inch below the axle easy enough.
Member of Team 5sfTe
post Nov 9, 2007 - 9:04 AM
Kadett
Joined Mar 17, '05
QUOTE(NEVERSTOP @ Nov 9, 2007 - 1:53 AM) [snapback]612447[/snapback]
Guess my ?'s are
thanks
Matt
Well guess we think alike. I also had in mind cutting the spare tyre well to make room for a over axle exhaust. But I did some touring around my town and other city's with speedbumps (We are #1 speedbump country I think) and all considered I think its not that bad to go under axle. I dont think I will hit anything with it.
I have Tein SS suspension on its stock (as delivered) setting with a 225/40/18 tyre (had a 35/18 tyre so its now 1/2" higher from the ground. (The drop the Teins give is about 1,5-1,7"in the back IIRC) I have about 8.5" of clearance from the rear subframe to the ground. So that will give about 5.5"of clearance which I will think is enough.
This post has been edited by Kadett: Nov 9, 2007 - 9:14 AM
post Nov 9, 2007 - 2:59 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I don't even think mine comes close to touching while I go over speed bumps. I'll see if I can park over the top of one and then take a picture to show clearance.
The main thing to remember is that when the shop is doing the exhaust, make sure they mock it up while the car is on the ground. Most places will put the car up on a lift and then fabricate the exhaust... this causes a problem. The rear suspension is extended all of the way down - they mock up the exhaust to hug up under this - they then lower the car and now wonder why they have 4"+ of a gap between the frame and the piping.
**** Photobucket
post Nov 9, 2007 - 3:06 PM
Kadett
Joined Mar 17, '05
QUOTE(95CelicaST @ Nov 9, 2007 - 8:59 PM) [snapback]612714[/snapback]
But 1 thing, what if you lift the back of the car (doing some maintenance, changing tyres etc). The suspension arms will hit the exhaust and put stress on it. Or would that be resolved by removing the rubber exhaust hangrubbers and let it rest on something? Not that I'm planning on doing much work on the back that requires that much effort but still.
post Nov 9, 2007 - 3:15 PM
95CelicaST
Joined Feb 5, '05
Yeah, thats what I have done. If it needs to go up they just detach the hangers and lower the piping down a bit, then tie it off to the hangers with some wire.
**** Photobucket
post Nov 9, 2007 - 5:45 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE(95CelicaST @ Nov 9, 2007 - 3:15 PM) [snapback]612722[/snapback]
that sounds like such a PITA.
post Nov 9, 2007 - 8:03 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I believe that's just a bracket. The support frame itself isn't different.
Lo-Fi Version Time is now: August 31st, 2026 - 3:50 AM
