> Climate Control Burned Out Question, This might be a new question.
post Nov 23, 2007 - 4:57 AM
trdproven
Joined Aug 2, '05
From Guam
My climate control bulbs do not light up only on the parts where it tells you how the vents blow. Is this normal for it not to work all across? Only the green square light above that icon works. How is that??
I've read the threads. I know there are two cables to remove in order to get the climate control out. Will I have to pull the climate control out with the whole length of both cables? I am also scared that I might not be able to put back the cable on the firewall side back.
Are there factory bulbs that I can replace it with without soldering? Like the typical oem plug and play style or twist style?
Thanks in advanced!
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Replies (1 - 3)
post Nov 23, 2007 - 5:31 AM
trdproven
Joined Aug 2, '05
From Guam
I just tried messing with it, as I removed some of the buttons and pressed them back in, that whole row of lights for the vents turned on but only for a little while. Now they dont turn on again. I think something is loose.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Nov 23, 2007 - 11:01 AM
lubu
Joined Apr 2, '07
From Great Western Plateau
QUOTE(trdproven @ Nov 23, 2007 - 7:31 PM) [snapback]616863[/snapback]
Check the stickies buddy im sure there are tons of infos on this...btw I think ur backlights are lose. try to tighten it.
98% completion
aaRon
post Nov 23, 2007 - 11:08 AM
Celicam8
Joined Nov 17, '07
QUOTE(trdproven @ Nov 23, 2007 - 4:57 AM) [snapback]616861[/snapback]
dont worry about that... there is a tube, you stick it in the tube and it will come out no problem... blue one is my right foot on driver side...
go through all the fuses and look if any are burnt out... my fog light fuse was busted... even though i dont have fogs, and it made my climate unit to stop working
Lo-Fi Version Time is now: August 11th, 2026 - 7:13 PM
