Nov 24, 2007 - 1:20 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
went to talk to the guy thats gona dyno my car and he asked me some questions i couldnt answer if someone could answer them that would be great
what are the stock size of the 7afe injectors what bar is the map senor on a 7a and does anyone have stock timing maps for the 7a -------------------- ![]() BOOST GETS YOU LAID!!!! |
Nov 27, 2007 - 10:59 PM
QUOTE(jesterwr217 @ Nov 24, 2007 - 1:20 PM) [snapback]617147[/snapback] went to talk to the guy thats gona dyno my car and he asked me some questions i couldnt answer if someone could answer them that would be great what are the stock size of the 7afe injectors what bar is the map senor on a 7a and does anyone have stock timing maps for the 7a and the guy at the dyno also told me that using an safc isnt a good idea because when you take away fuel you ecu adds more timng and this would blow the motor is this true? -------------------- ![]() BOOST GETS YOU LAID!!!! |
Nov 28, 2007 - 12:16 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 23, '05 From Princeton, Minnesota Currently Offline Reputation: 7 (100%) |
stock size is right around 180cc
stock MAP is 1BAR and yes when you take fuel out it adds timing thus possibly blowing your motor -------------------- -Brian
Nov 28, 2007 - 11:28 PM
hey thanks one more question...is there a way to adjust the timing on the motor
Nov 29, 2007 - 12:36 AM
rotating the distributor
well im not sure if it rotates or what not but from what i hear you can do some timing with it This post has been edited by Celiracer18: Nov 29, 2007 - 12:53 AM -------------------- -Brian
Nov 29, 2007 - 3:02 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
7A injectors are 210cc. To retard timing, you need to jumper two pins in the Diagnostics box (I don't remember which two), hook up the timing light, start the car, and retard the timing at the distributor by loosening the bolts and turning it counter-clockwise until you get your desired timing. Just to let you know, retarding the timing on the ST is retarded (no pun intended) and it's not even enjoyable or healthy. The turbo will spool-up a lot quicker, but the car will be very lazy. I did it years ago from stock 0 to -5 degrees.
About timing, I've boosted 5 PSI with 89 (or was it 87?) octane fuel many times and the engine has behaved like if it was on 93 octane. More (or less depending on ambient temperature) and the engine starts retarding timing. You can feel it because the car will not pull any stronger than at a lower boost setting, and you can hear the turbo sound different. If the engine needs to retard too much, it'll go in limp mode, with a cool orangey-sweet CEL for your enjoyment. It's oh-so-lovely cruising at 50 MPH while the turbo is spinning its ass off, with snail-slow throttle response to boot. I've tried to break this engine. I boosted 15 PSI on 93 octane at WOT (MX-6 turbo injectors, which are not enough fuel by the way), and the car would go nowhere, while the turbo sounded like a 747 about to take off. This post has been edited by OOBE: Nov 29, 2007 - 3:16 AM -------------------- |
Nov 29, 2007 - 10:00 AM
well we were also considering getting rid of the safc and going with a different piggyback called the smt-6 which you can control timing with
Nov 30, 2007 - 2:30 AM
I've read good things about that piggyback. I actually considered getting it, but settled for the e-Manage since it's more mainstream and tuners here know how to work it good. I mean, a good tuner could tune any EMS, but you know what I mean.
| Lo-Fi Version | Time is now: July 30th, 2026 - 3:19 AM |
