Dec 10, 2007 - 6:33 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) |
Now i know 5th gen celica's rear disc assemblies will work for are 6gc's by reading one of coomer's thread. While junkyard hunting today i stumbled on this camry, the rear struts looks the same and so does the placement of the brake line and end links, so im thinking it will work on the 6gc. just looking if anyone has sum more info on this and some more opionions. also btw my cell phone camera takes pictures backwards, i know its weird
Dec 10, 2007 - 7:01 PM
isn't the log pattern of Camry's different than the Celica's ?
Dec 10, 2007 - 10:17 PM
the 92 - 96 is the same.....
the 97 + changed to 5x114 -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Dec 10, 2007 - 10:42 PM
the bolt pattern has nothing to do with it. You would need the backing plate, caliper, torque plate, e brake stuff, ect...
FYI, these are the same as the st165 rears. -------------------- |
Dec 10, 2007 - 11:01 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
My 93 Camry had 5x114 lug pattern, Its Camry's before 91 that had 5x100 and the rest had 5x114.
Dec 10, 2007 - 11:41 PM
QUOTE(Batman722 @ Dec 10, 2007 - 10:42 PM) [snapback]621577[/snapback] the bolt pattern has nothing to do with it. You would need the backing plate, caliper, torque plate, e brake stuff, ect... FYI, these are the same as the st165 rears. I just though he would need different rotors as they won't go on the Celica hub. -------------------- ![]() |
Dec 10, 2007 - 11:45 PM
see you guys know more then me, of cousre i will get new rotors, sence that is a camry assembly i would get teh camry rotors my main concern is will this whole brake assembly bolt on to the 6gc?
Dec 11, 2007 - 2:58 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
I was in the same situation before only it was the front of the camry, and there just happened to be a 6gc right next to it.
I took the whole brake assembly from the carmy's front and put it up against the 6gc's shock. the 2 bolts that attach the whole assembly to the shock were about a 1/4 spread further apart compared to the 6gc shock. so that didnt line up. also the bolt that attatches to the lower control arm stuck out about 1/2 in further than needed. It seems like toyota ran the exact same style suspension but made the camry's components jus a BIT bigger than the celicas... it was really close but unusable in the front... i would bet the same for the back but i would double check anyway before purchasing. good luck.. let us know what you come up with. |
Dec 11, 2007 - 11:35 AM
hmm well i think im going to pass on this one, and keep searching thru the yards sum more. what sucks is that you never find a 6gc gt in a junk yard lol. Thank so much on the info guys, but ill eventally find a 6 or 5th gen with the rear assemblies i need
Dec 11, 2007 - 11:43 AM
ya its not going to fit i just found the answer on wiki's. it says that 3rd gen camry were added bigger brakes then the inexpensive 4 bangers back then so they could offically move it into the luxory sedan market lol. then it gave the specs, so yeah wont fit without fab work, too muhc for me...the search continues lol
Dec 11, 2007 - 9:36 PM
QUOTE(illneversellmycelli @ Dec 11, 2007 - 11:43 AM) [snapback]621733[/snapback] ya its not going to fit i just found the answer on wiki's. it says that 3rd gen camry were added bigger brakes then the inexpensive 4 bangers back then so they could offically move it into the luxory sedan market lol. then it gave the specs, so yeah wont fit without fab work, too muhc for me...the search continues lol I would love to have 5x114. more oem rim options..... This post has been edited by njccmd2002: Dec 11, 2007 - 9:36 PM -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
| Lo-Fi Version | Time is now: August 24th, 2026 - 11:11 PM |
