Dec 19, 2007 - 7:07 AM
Enthusiast ![]() ![]() Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
hey i cant find a 2 bar map sensor or a check valve...i just wanted to know what happens if my stock map sensor see boost?
Dec 19, 2007 - 11:27 AM
Enthusiast ![]() Joined Apr 28, '07 From Venezuela Currently Offline Reputation: 0 (0%) |
what are you planing to do?... you have turbo!? :S
Dec 19, 2007 - 2:42 PM
yea i do im puttin it all together but idnt wnat to till i change the map sensor...can i run on my stock map sensor till i get a 3sgte turbo pressure or a check valve???/
Dec 19, 2007 - 3:01 PM
I don't think that would be a good idea.
Dec 19, 2007 - 3:09 PM
ahh some please explain to me why tht would be bad what will it do to my car also if any oone has a 3sgte turbo pressure sensor or knows someone parting out thier 3sgte or has a turbo presure sensor for sell let me kno...but most important someone let me kno what r the consequnces if i run boost on my stock map sensor...or can i run boost on my stock map sensor till i get a 3sgte turbo pressure sensor.
Dec 19, 2007 - 3:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 13, '05 From Poughkeepsie, NY Currently Offline Reputation: 2 (100%) |
2 bar map sensor, or else. thats all you really need to know. With out it, your engine will go boom shortly.
This post has been edited by devilsden97: Dec 19, 2007 - 3:18 PM -------------------- ![]() Kawi Love |
Dec 19, 2007 - 3:22 PM
ok u say a 2 bar map sensor can it be any 2 bar map sensor or is thier a specif model??
Dec 19, 2007 - 3:31 PM
IIRC: every 2bar map sensor ive seen on a celica, is the stock 3rd gen 3sgte. (2nd gen has afm)
EDIT: http://www.6gc.net/forums/index.php?showtopic=5574 might help This post has been edited by devilsden97: Dec 19, 2007 - 3:50 PM -------------------- ![]() Kawi Love |
Dec 19, 2007 - 3:52 PM
IIRC...? does any one have the part #?
Dec 19, 2007 - 3:59 PM
IIRC means If I Recall Correctly.
search the stickies, or one of the other 5sfte threads. IT must be posted somewhere in there. -------------------- ![]() Kawi Love |
Dec 19, 2007 - 4:06 PM
some ppl are telling me to just use a fish tank check valve has anyone use tht oobe said it work great for him for two years are they easy to install do u have to do any custom work to fit them in??
Dec 19, 2007 - 4:25 PM
ok, listen up.
READ the Stickies plz. (the hyperlink i posted above) covers alot of things, most importantly, it covers the idea of cheaping out now, and ull PAY for it later. -------------------- ![]() Kawi Love |
Dec 19, 2007 - 5:28 PM
without a 2bar map your car will hit fuel cut as soon as it sees any boost.
fish tank parts are made for fish tanks, not cars. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Dec 19, 2007 - 8:17 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
i have used the check valves for a while and no problems . but it does not let you tune very well with the emanage unit so the 2 bar is a must.
Dec 19, 2007 - 8:24 PM
![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) |
i've kept my stock map on my 7afe running 13psi right now.....yellow top supra injectors and SAFC....haven't ran into many problems in the past 2 years its my DD.....need to rebuild the engine now..have oil burning in the combustion chamber...pretty sure its my rings (but plan on waiting till i get a new car before i do anything major).
....theres a hose in the back of the motor similar to a radiator hose its about 4 or 5 inches and thats about to burst..(if anybody knows what i'm talking about- what is it called? or do u have a part#....i was thinking i pull it off and go to a parts store and match up a radiator hose the same size and cut it)...starter is starting to crap out....but thats under warranty(autozone ftw) ....axles knocking again ...i think i've replaced them about 6 or 7 times in the past two years....thats under warranty also(O Riley ftw) their starting to ask questions.. the hardest part about giving up this corolla is all the warranty i'd lose |
Dec 19, 2007 - 9:41 PM
someone can help me by telling me where they got thier map sensor i made an account in mr2oc.com and alltrac.net and still nothing no one has a 3sgte map sensor.
Dec 20, 2007 - 1:24 AM
PLEASE CHECK YOUR FIRST POST!!!
Dec 26, 2007 - 8:11 AM
this is probrably a stupid question bought im not sure about it ....does and electronic boost controller need a wastegate??
Dec 26, 2007 - 8:55 AM
yes. either an internal or external wastegate. and its not the boost controller that needs one per say. without one you will boost till you turbo cant physically push anymore air. so you would be running a ton of boost... instant blow up your engine boost. so yes, you need a wastegate, regardless of mbc, ebc, or just an actuator.
Dec 26, 2007 - 3:27 PM
ok im not having the wastegate and the electronic boost controller install my self can i run with out it to the shop but have the boost gauge on which will tell me how much boost im pushing??
| Lo-Fi Version | Time is now: September 2nd, 2026 - 2:04 AM |
