> Itunes problem/question, lost library, can i relocate it all at once?
post Jan 12, 2008 - 9:49 AM
jcbass7
Joined Apr 20, '06
From Florida
I have about 180 gigs of music on my exernal hard drive and i play it all through itunes. but what tends to happen about once a month or so, if the computer freezes or can't locate my hard drvie it screws everything up in itunes.
when i reconnect the external my itunes library cannot be found. as in if i play a song i get the message
"the song ______ could not be used because the original file could not be found. Would you like to locate it?"
so.. i have two options.. i can locate each song (38,000) or i can delete all of my songs in itunes, lose my playlists and reload them all in itunes.. (<this takes a few hours to load them all.)
Is there a way i can reconnect the itunes player to the entire library it used to play?
Replies (1 - 4)
post Jan 12, 2008 - 9:56 AM
DangerboyJr
Joined Sep 30, '07
From Ontario
search for the Itunes Library file. Mine is in
c\documentsandsetting/chris/mydocuments/mymusic/itunes
That Controls your Entire Library as well as playlists
its an XML file
This post has been edited by DangerboyJr: Jan 12, 2008 - 9:58 AM
post Jan 12, 2008 - 10:07 AM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
this might help bro, kinda similar problem
http://www.askdavetaylor.com/why_cant_itun...d_my_songs.html
post Jan 13, 2008 - 12:09 PM
jcbass7
Joined Apr 20, '06
From Florida
Well i imported the XML file, but if just brought up the exact same library that will not play. I attribute this to the fact that itunes must have saved my "broken" library when i closed it after it had not worked.. so it saved over the XML file of the working library...
i guess i will just reload them all in and copy the XML file of the working one when it works and back it up somewhere else so i can use it in the future without it getting saved over?
post Jan 13, 2008 - 12:46 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
can you install itunes on the external HD? then you shouldn't have a problem.
Lo-Fi Version Time is now: September 3rd, 2026 - 5:04 PM
