> HA! Anyone think this is legit?, Crazy performance
post Feb 10, 2008 - 4:12 PM
CelicaST94
Joined Sep 23, '07
From Scranton,PA
http://cgi.ebay.com/ebaymotors/PERFORMANCE...tem310020983558
Designed Specifically for: TOYOTA CELICA 1990-2008
Part Number: 892-6262KTR
ACR performance chip specifications
- 60+ Horsepower (65-70+ HP on trucks and SUV's)
- 60+ Ft. lbs of Torque ( 65-70+ Torque on trucks and SUV's)
- 20+ MPG better fuel Efficiency GUARANTEED!
- Faster Acceleration
- Faster Track times
- Improved 1/4 and 1/8th mile track times
- Better mid-range acceleration
- Higher Top-End power
- Increased towing power
- Smoother shifting (Automatic and manual transmissions)
- Smoother Idle
- Extends the life of your spark plugs
- Extends the time between costly engine Tune-ups
- More low end torque
- 75%+ Quicker throttle response time
- Cleaner Engine Heads
- Cleaner and faster revs
- Higher Top-Speed and Improved Top-End Torque
- Better Climbing ability
- Improved HP and Torque Output in High Altitude Areas where the air is thin
- Increased Passing Ability
- Better and Crisp throttle response
- Circuit Protection
- Better Mid-High RPM Revs
- Helps your vehicle to Pass SMOG and EMISSIONS Regulations
- Street Legal Everywhere
- Pays for itself by saving gas
- Cleaner Spark Plugs ( Less repairs and tune-ups )
- Cleaner Engine heads ( Less repairs )
- Lengthens the life of your engine belts by reducing Engine RPM's
- Smoother Power in all power band levels
- Causes less stress on your engine, making your engine last even longer
- Dyno Proven
- Extends the life of your oil and extends the life of your oil between oil changes
What you will receive:
- 1 Circuit protected ACR Performance chip kit
- Lifetime no hassle, no questions asked warranty
- 1 Set of ACR Performance Installation instructions ( Installation takes less than 5 minutes to install. It's so simple with our installation instructions, if you can plug an electrical plug into the wall, you can install our chip!
- 100% No hassle, No questions asked money back guarantee
- Will work on 3, 4 ,5, 6, 8, 10, and 12 cylinder vehicles. ( We program our chips to correspond with your vehicle's ecu and then our chip automatically adjusts to the size of engine you have)
- 24/7 Technical support for any vehicle ever produced.
- Lightning Fast shipping. Our shipping at ACR Performance is one of a kind. We ship your module within a few hours of receiving your payment!
- You will also receive a shipping confirmation after your order has been shipped
How our module works:
Since 1998 we have been producing performance chips. In 1995 we purchased all of the performance chips currently available on the market. We found that each performance chip that we used had given us a performance gain in some way or another. We had run over 300 times on a dynamometer using the same vehicle with only one different variable, the different performance chip. After seeing that the average cost of the performance chip was over $300 we wondered how are these chips made. We then spent the next two years researching and through experienced electrical technicians we had discovered the SECRET. We then created 500 prototype performance chips and placed them on 500 different vehicles for testing. With a 100% success rate on every vehicle and not one of them failing we decided to offer our performance chips to our local area for sale. We have now sold over 1 million chips to our local area and throughout the USA. We have recently made some changes and decided to sell our performance chips on eBay. Since 1990, fuel injection has been in every vehicle produced. Fuel injected vehicles run on a ECU or PCM board which are basically fancy terms for a computer. We have studied and figured out that every vehicle from the car manufacturers runs rich from the factory. Your vehicle's performance relies on an Air/Fuel ratio in order to function properly. The air/fuel ratio runs at 3 different levels: Rich, Stoich and Lean. The vehicle manufacturers try to produce as much power as possible without sacrificing engine reliability, better gas mileage and the mileage between tune-ups. Our job was to figure out how to produce more power and give better gas mileage at the same time. When your vehicle is running rich you are wasting gas. For example: If you have ever seen a person accelerating quickly you may have seen black smoke coming from the back of the car, this is NORMAL. The black smoke is un-burnt fuel coming out in a liquid/gas form. This un-burnt fuel should stay in your gas tank. There is no need to throw money out the window. When your air/fuel ratio runs at stoichometric levels you are getting optimum performance along with better gas mileage. Our performance chip will allow your vehicle to run at stoichometric levels at all times! You will not need to use premium fuel although it does help our chip work even better! We are offering the current price on eBay as an introductory price and the price will go up. We are also offering a 100% money back guarantee to prove to each and every one of our valuable customers that this will give you more horsepower and save you gas money each time you go to the pump. Try one today, you cannot go wrong with our 100% hassle-free money back guarantee!
Frequently Asked Questions:
- Q: How do you sell it for such a low cost?
- A: Like some huge companies, you deal with a middleman. With us, there is no middleman involved, we are a family owned company and we have our own 10,000 sq. ft. Facility in which we Build, package and ship our own items. We also order all of our supplies in bulk. We are also offering the current price as an introductory price. So be sure to get one today! You have nothing to lose with our 100% Money back Guarantee!
- Q: Will this work on turbo/supercharged vehicles?
- A: Sorry, we are currently in development of making it work with turbo/supercharged vehicles.
- Q: Can I pick up my module locally?
- A: In order to keep our costs down, we can only ship our performance products.
- Q: Will this work on diesel vehicles?
- A: Sorry, Our modules will not work with diesel engines at this time.
- Q: Will your module hurt or damage my engine?
- A: NO! Our module will not hurt or damage your engine in any way!
- Q: Will your module void my warranty on my vehicle?
- A: No, Our module will not void your warranty. You will not run into any warranty issues!
- Q: Do you have a return policy? Is there a warranty?
- A: Yes, we offer a hassle free 100% money back guarantee! Your module comes with a hassle free lifetime warranty.
- Q: Will your module work on automatic and manual transmissions?
- A: Yes, our module will work with all transmissions!
- Q: Will I need any special tools or will I need to take my vehicle to the mechanic to install the module?
- A: NO! This is the best part about our chip! We include the BEST installation instructions. You will be able to install our module in less than 5 minutes. If you can plug a electrical cord into the wall, you can install our chip! You will not need any special tools. You will not need any tools in fact! Also, there is no cutting, splicing or any kind of soldering required. Our module is plug and play installation!
Shipping and Handling
All Shipping fees include postage, material and handling fees!
- Shipping to Entire USA, Puerto Rico and Hawaii - $6.85
- Shipping to Canada - $7.25
- International shipping outside the USA and Canada - $8.85
- Priority shipping ( USA ONLY and Tracking info will be sent) - $11.59
- Shipping insurance ( Optional and USA ONLY) - $1.65
- NOTE: We combine shipping on all items! Purchase more than one item and we will ship any additional items for free!
Delivery time is estimated between 2-5 days from the day your order is placed. We ship immediately upon receiving your payment.
ATTENTION: We have a connection with our local post office which allows all of our orders to be shipped at 6 different times daily. Due to the large amount of orders we currently receive, your chip will be shipped approximately 2-4 hours after payment is received. WE GUARANTEE ONLY THE FASTEST SHIPPING!!! Order at any time of the day and your order will be packaged and be at the post office ready for shipment within 2-4 hours.
Payment Options
- Paypal ( Preferred )
- Money order
- Certified Checks
- Personal or Cashier's checks
- Paypal E-Check
Questions?
if there are any questions you may have or need help or assistance with anything please feel free to contact us. Our helpful Customer service employees are here and willing to help you with any concerns or questions that may arise. Please feel free to contact us at: CustomerSupport@ACRperformance.com
If you are looking to save more fuel and still gain performance please check out our store and take a look at our fuel saving modules. Our Fuel saving modules will save you 25+ MPG Guaranteed. Keep in mind our module makes a great gift for family members or friends. If you would like your module sent specifically to a family member or friend please make a short note in your Paypal or mail delivered payment and we will ship to their address. Also if you purchase more than one module, we will ship any additional modules to you at no extra charge!
We would like to thank you for taking the time out of your busy day for looking at our page. Have a wonderful Day!
ALL WEBSITE CONTENT, PHOTOS AND COMPANY NAME ARE COPYRIGHT OF ACR PERFORMANCE MOTORSPORTS INC. ANY DUPLICATION WILL RESULT IN LEGAL ACTION.
Replies (1 - 9)
post Feb 10, 2008 - 4:15 PM
95st-celica
Joined Mar 29, '07
From Philly
lol.....no
1988 Dodge Aries K (sold)
post Feb 10, 2008 - 4:27 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
wow that guy is making bank selling a 20 cent resistor for 8 bucks.
post Feb 10, 2008 - 4:28 PM
enjoi926
Joined Jul 19, '07
From Worcester, Ma
jesus..... I didn't even know ebay sellers still attempted to sell those, they were played out in 2001. And no they aren't legit.
post Feb 10, 2008 - 4:59 PM
D-Man
Joined Jan 18, '08
From Houston
We've all heard the saying: "If it sounds too good to be true, Than it isnt True"
I wonder why its such a respectable busniess; but yet:
QUOTE:
"- Q: Can I pick up my module locally? "
"- A: In order to keep our costs down, we can only ship our performance products."
Nor does it give an address or even what country this building is located.
Do you think you'll get your money back when it dont work? Hahahaha laugh.gif
no you wont.
Damn D-Man - most impressive.
post Feb 10, 2008 - 5:57 PM
tonytutino
Joined Jun 16, '06
From Bowling Green KY
better revs but reduces engine RPM's? lol
no.
i'm so sick of seeing these things all over ebay. and i feel sorry for all the people buying them. you will not get 70hp from simply plugging something in your car tongue.gif
but! since they say they will give you your money back and its a violation of eBay terms if they don't, it would be funny to call their 24-7 tech support when you try to explain to them why it doesn't work and you want a refund.
post Feb 10, 2008 - 6:06 PM
laff09
Joined Jul 28, '06
From Delaware
WORD improved towing . sign me up...
post Feb 10, 2008 - 6:45 PM
1990-2008 Celica should have given you a tip right there bud. laugh.gif laugh.gif laugh.gif
post Feb 10, 2008 - 7:44 PM
MaskedMan
Joined Jun 29, '03
From 캘리포니아
QUOTE(Bitter @ Feb 10, 2008 - 3:45 PM) [snapback]640126[/snapback]
I loves me my 2008 Celica so much smile.gif.
post Feb 10, 2008 - 8:02 PM
yea, i think the OP gets the idea.
these scam products do not work.
Closed TopicStart new topic
Lo-Fi Version Time is now: September 14th, 2026 - 9:49 PM
