Feb 13, 2008 - 12:11 PM
![]() Enthusiast ![]() Joined Jan 28, '06 Currently Offline Reputation: 2 (100%) |
Has anyone with 3S-GTE conversion and an ST205 cluster tried to swap the GT-Four's speedometer/odometer with a US speedometer?
Feb 13, 2008 - 1:27 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
More or less i have done something like this..
I have a 94 USDM GT with a 2nd gen 3sgte, but for the speedometer i have an ST205 cluster with a TRD 300mk speedometer. In all theory it should work fine. its just four screws and the speedo is swapped out. http://www.6gc.net/forums/index.php?showto...ass7&st=240 Check out halfway down that page, talks about it a bit and shows some pics |
Feb 13, 2008 - 2:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
you mean something like this???
btw i found that some st205 clusters where actually wired a bit differently depending on edm and jdm. The easiest way to do the rewire was to sit the usdm and jdm/edm custsters side by side and trace back all the inputs and grounds. Then make a chart that would aid you when you move the pin/wires around on your usdm harness to match whats on the jdm/edm cluster. After all was done the cluster works totally fine. |
Feb 13, 2008 - 4:11 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) |
Or you could just use the how-to I made:
http://www.6gc.net/forums/index.php?showtopic=30411 It has a guide for the JDM, EDM, and Australian versions. -------------------- ![]() Project ST204.5 99.88946% complete... |
Feb 14, 2008 - 2:13 AM
Thank you all for the great responses, they were immensely helpful.
Feb 14, 2008 - 3:33 AM
QUOTE(WannabeGT4 @ Feb 13, 2008 - 1:11 PM) [snapback]641182[/snapback] Or you could just use the how-to I made: http://www.6gc.net/forums/index.php?showtopic=30411 It has a guide for the JDM, EDM, and Australian versions. no disrespect at all but when i did mine i found that not all of pin outs listed there matched what i had so i ended just making my own list so i knew for sure it was correct.. i have a feeling that they changed some of the pin outs depending on year and/or type of gt4 it came out of. although ur guide was a great help at figuring out what direction i needed to go. This post has been edited by urbandork: Feb 14, 2008 - 3:35 AM |
Feb 14, 2008 - 9:25 AM
QUOTE(urbandork @ Feb 14, 2008 - 2:33 AM) [snapback]641390[/snapback] QUOTE(WannabeGT4 @ Feb 13, 2008 - 1:11 PM) [snapback]641182[/snapback] Or you could just use the how-to I made: http://www.6gc.net/forums/index.php?showtopic=30411 It has a guide for the JDM, EDM, and Australian versions. no disrespect at all but when i did mine i found that not all of pin outs listed there matched what i had so i ended just making my own list so i knew for sure it was correct.. i have a feeling that they changed some of the pin outs depending on year and/or type of gt4 it came out of. although ur guide was a great help at figuring out what direction i needed to go. Do you happen to have the list you made for your particular combonation meter? I'd be more than happy to update the guide. -------------------- ![]() Project ST204.5 99.88946% complete... |
Feb 14, 2008 - 1:52 PM
I totally forgot to mention the wiring part.. i haven't started that yet.
This post has been edited by jcbass7: Feb 14, 2008 - 1:52 PM |
Feb 19, 2008 - 5:41 PM
It seems there was a bit of confusion in my question. All of the wiring in my car, short of in the doors and rear lights came out of an ST205. So, swapping the speedo was extremely easy. A direct swap with no need to change any of the wiring.
Feb 19, 2008 - 6:44 PM
QUOTE(urbandork @ Feb 13, 2008 - 2:46 PM) [snapback]641152[/snapback] you mean something like this??? btw i found that some st205 clusters where actually wired a bit differently depending on edm and jdm. The easiest way to do the rewire was to sit the usdm and jdm/edm custsters side by side and trace back all the inputs and grounds. Then make a chart that would aid you when you move the pin/wires around on your usdm harness to match whats on the jdm/edm cluster. After all was done the cluster works totally fine. Ive been wanting to do that with mine for a while now. I always forget that i have a 7k redline. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 20, 2008 - 4:13 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
i think art just wants the fancy lil turbo psi gauge
good work on the swap!! -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:50 AM |
