> Timing belt - pulley replacement
post Feb 17, 2008 - 5:40 PM
valerit1
Joined May 2, '06
From Nevada
All my toyota dealerships do not replace those when timing belt is replaced - just check.
How often do they lock up?
Replies (1 - 6)
post Feb 17, 2008 - 5:53 PM
3SGTE
Joined Jun 13, '07
From U.K
QUOTE(valerit1 @ Feb 17, 2008 - 10:40 PM) [snapback]642530[/snapback]
I think its about 60k-70k if i remember buddy.
post Feb 17, 2008 - 6:19 PM
RichieRichJP
Joined Feb 7, '08
From Colorado Springs, CO
I'm obviously way over due on this. I bought my car at 57K and I'm currently 128K without changing it. I'll be getting a new belt and tensioner in the next two weeks though. It's starting to chirp a little
post Feb 18, 2008 - 12:55 PM
RisingSun1
Joined Sep 29, '06
From US
Is it just the tensioner or the other pulleys to?
post Feb 18, 2008 - 3:20 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
the tensioner, idler, new spring, and might as well do the water pump while your at it.
post Feb 18, 2008 - 9:27 PM
valerit1
Joined May 2, '06
From Nevada
Actually, I just asked how often they go bad if not replaced with the timinng belt.
Another way of putting it how high a chance for those to last two timing belts intervals.
post Feb 19, 2008 - 1:01 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
probably none. they will first make a grind noise like a bad alternator and then they will seize on ya.
Lo-Fi Version Time is now: August 2nd, 2026 - 12:21 PM
