> Hey got my injectors back and have a question.
post Feb 23, 2008 - 1:12 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
So I got my injectors back from witchhunter and they were tested and cleaned by them. So I get it back and looked at the chart, and although the injectors were dirty to begine with only one of them was fair. I looked at the numbers and aren't the injectors supposed to be 315's? I sent them the supra na injectors green top. The numbers came back and it said that they were flowing like 124 or something. Can someone fill me with some info. I'm a bit confused at the moment.
94 Celica gt white (sold)
Replies (1 - 4)
post Feb 23, 2008 - 6:38 PM
QUOTE(bccentaur3 @ Feb 23, 2008 - 1:12 AM) [snapback]644815[/snapback]
can you post the pic?
if your planning on using them (the 315's) for a 5sfte, i wouldnt.
its been dyno proven that you will run dangerously lean with them under boost.
as lean as 17:1
post Feb 23, 2008 - 10:24 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Okay they were being tested at 43.5 psi. And the flow rate was more like 129. Yes, I am planning on running them on my 5sfte project. So I'd go as lean even at factory boost? I wouldn't be able to run these for maybe a couple of weeks?
post Feb 23, 2008 - 11:42 PM
QUOTE(bccentaur3 @ Feb 23, 2008 - 10:24 PM) [snapback]645043[/snapback]
i ran them for a couple months at 9 or so PSI, but i wouldnt recommend them to anyone else.
its just plain dangerous.
post Feb 24, 2008 - 12:13 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Alright Manny, I have just taken your advice and picked up CaliJeff's injectors and neo. wink.gif
Lo-Fi Version Time is now: August 31st, 2026 - 8:19 PM
